Seat belt problem...
Old Jul 31, 2009 | 02:02 AM
degaine_designs's Avatar
degaine_designs is on a distinguished road
Default Seat belt problem...
The passenger side front seat belt in my '89 S15 Jimmy is stuck. I've tried pulling and it won't budge. How do you remove the plastic cover around the seat belt on the floor? If I could get it off I'd be able to see where the belt is stuck, but I can't remove it, it seems to be stuck in one spot. Are there any hidden bolts holding the cover on?
Old Jul 31, 2009 | 11:40 PM
Typically there is a rivet holding the plastic on in the back side of the assembly. It can be a real pain to get off. I was removing the seat belts from a 90 Suburban and almost cut my finger off when the thing finally let go. There is sharp metal in there!
Old Aug 1, 2009 | 01:25 AM
How would you suggest getting it off safely? I need my fingers as I draw for a living.
Old Aug 1, 2009 | 12:38 PM
There should be a plug that you can remove to get at the bolt that mounts everything to the floor.
Old Sep 10, 2009 | 07:21 PM
I finally got around to replacing the belts. I got them used from eBay. I bolted them into the truck and went to test them and the lower belts move freely but the upper belts are locked up and won't budge. I moved the lock by lifting it and can pull the belt out while holding the lock but then it wont retract without getting stuck thus rendering the belts unusable. Any ideas on what is wrong?
KAK
May 29, 2016 08:05 AM
lionel2
Sep 7, 2012 02:45 PM
kbp99v
Apr 9, 2007 01:24 PM
gizwilly
Dec 11, 2006 01:05 PM
