Smells rich.Idea's?
Old 07-21-2011, 12:52 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Default Smells rich.Idea's?
So for a LONG time now my 91 has always smelled pretty bad when running. Almost like a rich smell. It runs great! No smoke etc out the tailpipe, just a bad smell that ive ignored since i got it. plugs are clean,no carbon at all. I seafoam it etc and make sure its clean.
Heres what i have replaced in the last 6 months :
plugs ac delco's,then switched to ngk v powers. No change in smell. runs good.
wires,im using autozones brand,or advance auto's. I dont remember
Cap & rotor with brass terminals.
Bosch O2 sensor. (never been fond of bosch,the o2 sensors alright?)
Timing is 4* advanced. Tried it at 0* for a week and no change in smell. so back to 4*
Fuel pump & filter (ac delco)
Temp sensor
180 stat
Ive cleaned the :
throttle body,egr,and iac several times.
One thing ive noticed is the cat was gutted when i got it. Do they make any change in the smell of exhaust at all? The tbi unit has never been rebuilt. Im going to do that sometime soon. Like i said the thing drives great. Idles smooth,never bogs down etc. Its just always smelled funny.
My next idea is the Ignition control module?
Old 07-21-2011, 06:20 AM
xgiovannix12's Avatar
Temp sensor
180 stat
Ive cleaned the :
hey chris are you leaking fluids on the y pipe?
Old 07-21-2011, 08:42 AM
How is your fuel mileage?
How do the plugs look?
With out a functioning catalytic converter to burn up the combustion byproducts, it will smell different than a vehicle with a properly functioning cat. Do you know anyone with a vehicle that isn't running catalytic converters that you could use to compare the smell?
Old 07-21-2011, 10:34 AM
chris015's Avatar
Did,the pos oil adapter housing was leaking. but i fixed that a long time ago. its not coming from vapors of leaky oil
My dad has his 91 cpi blazer with a cat. His does not smell this way.
Plugs look great. No fouling at all.
Im getting roughly 17 mpg city and 19 highway running 3.42 gears,30" tires.
Old 07-23-2011, 10:49 AM
ely0569's Avatar
ely0569 is on a distinguished road
Pull the plenum off and make sure you don't have a leak of the spider injector or the lines going to the injector. Mine was smelling the same way, and that was the issue. **Just a thought**
Old 07-23-2011, 01:33 PM
chris015's Avatar
I have the tbi injection. Cpi didnt start until 92. (i think so,ive never seen a 91 cpi)
Old 07-23-2011, 01:38 PM
could be cause that cat was removed . When i cut my cat off when it went up on fire since it was clogged the truck smelled terrible for a few weeks till i put a new cat and exhaust in
Old 07-23-2011, 01:49 PM
chris015's Avatar
Yes im starting to think its my catty. Problem is i cant buy one at a junk yard since they just scrap them for easy money. Time to find a aftermarket dirt cheap cat. I dont think it matters if its for a blazer or not as long as the pipe size is the same and its not tiny.
Old 07-23-2011, 02:11 PM
i think you can find 60 buck ones on ebay
Old 07-23-2011, 02:39 PM
chris015's Avatar
Looked at advance auto. I can get a magnaflow for 50 bucks after coupon codes and pick up in store. SCORE!
I wonder how this is going to affect the exhaust tone and performance. truck drives like a raped ape..Oh well,im sick of the smell.
Quick Reply: Smells rich.Idea's?
