Speed sensor operation
Old Sep 14, 2010 | 05:35 AM
terry2707's Avatar
terry2707 is on a distinguished road
Default Speed sensor operation
I am trying to troubleshoot a non-working speedometer/odometer problem on a '91 S15 Jimmy 2wd with a 5-speed manual transmission. I have tested the speed sensor voltage output while it was removed from the vehicle and it shows to be good. The strange thing is that when I re-install it, put the rear axle on jack stands and test the sensor with the wheels turning, the sensor shows no voltage output. That makes me wonder if the "trigger" inside the transmission is missing or damaged. Can somebody tell me exactly where and how the "trigger" is located in the tranny? I can look in the opening where the speed senor is located and see a gear. Is there a magnet attached to this gear that serves to trigger the speed sensor to produce it's voltage, or possibly is the magnet mounted on the rotating shaft? Any help or info is appreciated. Thanks!
Old Sep 14, 2010 | 10:01 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
the gear you are looking at is actually a reluctor ring, just a piece of round metal with notches in it..... heres an example of one.... http://img.auto555.com/photo/product...UCTOR-RING.jpg .... the magnet is inside of the speed sensor and when ever a tooth on the ring goes by the magnet it created a small AC current. the faster the spped the higer the AC voltage... so set your DDM to AC not DC and see what you get
Old Sep 15, 2010 | 03:49 AM
terry2707's Avatar
Thanks for that info...I think it will help in solving my problem. Previously, when I took the sensor out, I checked the output voltage by holding the sensor near a spinning magnet and did get a voltage reading. At the time, I knew the sensor had a magnet inside it, but didn't know if the reluctor ring itself was magnetic also, or non-magnetic. I will try testing the sensor again using a non-magnetic piece of metal and see what kind of reading I get. Thanks again for the help!!!
Old Sep 15, 2010 | 05:24 AM
R2P's Avatar
R2P
R2P is on a distinguished road
It might not even be AC, it could be pulsed DC. If so, you'll probably need a multimeter capable of measuring duty cycle or an oscilloscope to measure it properly.
Old Sep 15, 2010 | 06:49 AM
terry2707's Avatar
I think you are correct R2P....I remember reading somewhere that the output voltage from the speed sensor to the DRAC is not AC, but rather DC. I'm not quite sure what pulsed DC is....my voltmeter set at DC would not measure pulsed DC correctly? Thanks for your help!!!
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
Sunshine Coaster
Sep 11, 2008 12:47 PM
CLSC1964
Dec 11, 2006 11:37 PM
