Sputtering, please help!
Old Mar 31, 2018 | 10:12 AM
Lefet's Avatar
Lefet is on a distinguished road
Default Sputtering, please help!
3 days ago it wouldn't start. Sprayed some carb/choke cleaner in the throttle body, it started. Seems like when it cools, I have to repeat the process. Today, driving from work it started sputtering on the parkway. I have to drive from NJ home to PA, but am afraid of breaking down. Any idea on what it could be? I'm going to thoroughly clean the throttle body. What else should I look for? Could the TB sensor be bad? Idiot light comes on sporadically. It's got about 8k miles on a complete tune up.
Any help would be greatly appreciated.
Old Apr 1, 2018 | 08:12 AM
Lefet's Avatar
Can anyone at least give me a direction to begin? I can't just start throwing parts at it. What (and how) can i do to begin to eliminate the various possibilities? Fuel pump was tested, it's up about 58. Could it be the fuel filter? Would jumping the ALDL thingy point me in a direction?
And of course, forecast has changed to supposedly 6" of snow today!
Old Apr 1, 2018 | 08:50 AM
chevyriders's Avatar
Did you check the fuel pressure right out of the pump? Or in front of the fuel filter?
Old Apr 1, 2018 | 10:01 AM
Lefet's Avatar
It was checked from right behind the engine next to the distributor cap.
I also just jumped ALDL plug and got 23, 32, 35 & 45. So I'll start there. Also wouldn't start today without the carb cleaner.
Old Apr 1, 2018 | 10:35 AM
Lefet's Avatar
Which is which? There are 2 sensors, one right above the TB, kind of oblong, the other a little farther back and round. Both have 2 screws. On one, (closest to TB) one of the screws is stripped. Also, can I use carb/choke cleaner instead of brake cleaner? I don't ha e any brake cleaner.
Old Apr 1, 2018 | 11:47 AM
I don't know much about the tbi engines, if 58psi is within spec it doesn't sound like the fuel filter could be the issue, because you tested it after the filter.(though, it's never a bad idea to change it out anyway.)
Did you find out what the codes are for?
Old Apr 2, 2018 | 01:14 PM
Lefet's Avatar
So far what I got is: 23- IAC, 32-MAP, 35- IAC, clean and 45- 02 sensor, rich.
I don't really know what all of that means but I cleaned the IAC (I believe, round with a paddle that opens/closes) and the MAP sensors. The truck started but only because I put cleaner/starter fluid in the TB. Once I start riding, it will start sputtering and spitting. I'm afraid it will die on the road and I'll have to have it towed.
Once it sits and seems everything settles down, it won't start again unless I spray some fluid in the TB. I wish I could get this figured out, I need to get home.
Old Apr 3, 2018 | 11:08 AM
Lefet's Avatar
Anybody?
I don't have the money to put it in the shop, nor the $$ to just throw parts at it.
Can somebody give me a direction to start looking?
After sitting, it won't start without fluid. Once running, 40-50 mph it starts sputtering. I'm afraid of driving it and getting stuck on the side of the road.
Old Apr 4, 2018 | 10:42 AM
Lefet's Avatar
So another day of no spray, no start. I did the paper clip trick again and came away with the same codes: 23, 32, 35 and 45. Anybody with any idea on where to start?
Old Apr 4, 2018 | 11:35 AM
Rusty Nuts's Avatar
The lowest code number is 23. Intake air temperature. Look up the spec for that sending unit. It's a chart that gives an ohm resistance against temperature. Measure the resistance of your sending unit and the temperature and compare yours to the chart. That will tell if the sending unit is the problem.
