Start problem -93 vin W engine
Old Dec 21, 2014 | 06:02 AM
Czenda's Avatar
Czenda is on a distinguished road
Originally Posted by GoldOlds94
Any luck yet with the motor starting? I'll do some research for you. I enjoy helping people solve their problemsm.
Hello No, any luck.. I try join fuel pump on 12v ,pernamently.
Pressure stay on 60 psi, during start, but nothing more..
Still wont start. About ICM, I dont found any bad points, or cracks..
Old Dec 23, 2014 | 06:55 AM
Czenda's Avatar
I have a news.. I try dismount and mont back a fuse block.
Now fuel pump relay doesnt fast "clic", abut fuel presure jumps to 60 psi and falling a fast ... and when I try on ignition after 10 sec, fuel again jumps to 60 psi.
Old Dec 25, 2014 | 06:40 AM
GoldOlds94's Avatar
GoldOlds94 is on a distinguished road
Fuel pump pressure is around 60 psi so that's good and there is spark. How about you injectors/fuel pressure regulator. Know as (spider) injector. I had to replace my unit 3 times already. Other then that it hast to be a bad sensor, like crank,cam,oil,coolent sensor.,knock. Just one of those is faulty equals no start. Have you checked the ignition timing?
Old Dec 26, 2014 | 11:54 AM
Czenda's Avatar
Before bodyworks engine rnun perfectly. Its a possible,that the timming was wrong all at once ??
https://www.youtube.com/watch?v=ZeDC...ature=youtu.be
Old Dec 28, 2014 | 04:26 AM
Czenda's Avatar
Problem solved )
Old Dec 29, 2014 | 10:31 PM
GoldOlds94's Avatar
So you got it running now. What was the problem? Something simple? I am happy to hear that. Finally
Old Dec 30, 2014 | 03:12 PM
Czenda's Avatar
Bad onntact on ICM.. :/ Now its running, with a little bad idle
Old Jan 5, 2015 | 12:20 PM
Czenda's Avatar
Lol, problem are back.
I ran out of the tank, add a new gas and now its again wont starts, rotate, sometimes have a hint of start..
Old Jan 7, 2015 | 12:37 PM
Czenda's Avatar
Update : After next spark plugs change,engine start,but for a few minutes
If I have a rich mixture, engine stops and wont start, plugs are black / carbon and wet from gas.. What its mean.. bad pressure or IAC ? Idle is very bad
Old Feb 8, 2015 | 04:10 PM
Czenda's Avatar
Fine, I have a new pressure regulator and next fuel pump.. but When I turn the ignition key, the in-tank electric pump starts up, but the pump relay starts to click-clack very fast. Within few seconds I switch the ignition off and back on and pump relay starts up again instantly – what should not happen, of course. Relay is brand-new, as well as the pump, fuses work well. OBD does not work any more either. This has happened once already, but it stopped of its own accord. Hence, the pump does not pressurize to the original pressure value of 61Psi and I do not know where to look for the malfunction.
Thank to all for help..
