Starter & radiator flush
Old Mar 29, 2008 | 04:06 PM
curse's Avatar
curse is an unknown quantity at this point
Default Starter & radiator flush
As some may have seen in my new member post i said i had starter problems, well I put in a new starter this time with a LLT warrenty. Problem is still there, i dont hear the "ggzzzzzzzzzZZZZZZ" sound anymore, but it sounds like it has problems turning over like it did before. It will turn over eventually but just having problems doing it so I dont know whats next to look at.
Also I have no clue where the pet **** is on my radiator, I looked everywhere for it and nothing. Is there an easier way to drain the radiator?
1994 S10 Blazer W engine
Old Mar 29, 2008 | 04:14 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Starter & radiator flush
#1 starter, have you checked the charging system yet? if so did you do charging while running and then load test on the battery?
#2 flushing radiator, you could pull off the bottom radiator hose and let the water gush out ...
Old Mar 29, 2008 | 10:53 PM
curse's Avatar
I don't know how to check the charging system. If you are talking about the alternator then i still don't know how to check if its working properly. I don't think my blazer has a charging system warning light either.
But now that I'm reading up on a google, the problem might be my battery as I have not checked since I had it and I have no clue how old it was before that.
Old Mar 29, 2008 | 11:02 PM
rriddle3's Avatar
Take it to the nearest AutoZone and they can test your battery and alternator for free.
Old Mar 30, 2008 | 04:26 PM
curse's Avatar
just got my battery and alt. checked at autozone, both checked out well. Althought it has not started rough today either so I don't know, thanks for the help.
Old Apr 3, 2008 | 04:45 AM
mr.vls's Avatar
What is the condition of the battery wire to the starter? You can have everything ok but if the battery wire is in poor condition the wire will not carry the amps. Same with the ground cable from the battery.
hroofblaze96
Jan 15, 2020 04:39 PM
pfsantos
Sep 23, 2010 03:58 PM
bigdaddykane93
Jan 4, 2010 12:03 PM
portcqb
Apr 29, 2008 09:56 AM
ZR 2
Dec 4, 2007 03:53 AM
