Still Having Problems
Old Jun 15, 2010 | 09:15 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
Default Still Having Problems
Ok, I'm still having problems with my 94 Jimmy 4.3 CPI.
Problem - Wont Start on its own. Must use Starting Fluid. Fuel Pressure is 45-50 psi when trying to start and is a constant 50 psi while Idling. Once running it runs like a champ, no stalling or bucking, nothing. Can drive on the highway at 70 mph, without worries.
Things I Have Tried -
Fuel Pump Relay replaced, no help
Used Spider Injector swapped in, no help
A New Fuel Pressure Regulator installed, no help
New Fuel Filter put in, no help
Suggestions - ?????
I havent done the fuel pump, becuase I believe if it was the pump it wouldn't run at all or run like crap. Please help, I'm tried of having to pop the hood and spray fluid into the throttle body everytime I want to go somewhere.
Old Jun 16, 2010 | 12:33 PM
mosfetpioneer's Avatar
mosfetpioneer is an unknown quantity at this point
It could be the pump
your pressure with the key on should be around 55-60 from what ive read/heard
Old Jun 16, 2010 | 07:57 PM
grimace007's Avatar
grimace007 is on a distinguished road
do yourself a favor and use carb spray instead of starting fluid.
.. try turning the key on and off a few times before starting it.
let it sit on a few seconds each time you turn it to run...
check the schrader valve on your fuel rail make sure its good and snug.
mind you i have little experience with these 4.3 blazers this is just general diagnostics on FI starting issues
Old Jun 16, 2010 | 08:18 PM
94BlazerPA's Avatar
I have tried letting it sit and build pressure for a few sec's.
Why should I use carb cleaner over starting fluid? What am I doing wrong?
Old Jun 17, 2010 | 01:57 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Agree it could be the pump. Your pressure is a little low. Any codes?
Old Jun 17, 2010 | 02:39 PM
94BlazerPA's Avatar
The SES light isnt on and it hasnt come on. Could there be codes stored in there?
Why Carb cleaner over Starting fluid?
Old Jun 18, 2010 | 09:50 AM
grimace007's Avatar
carb spray is less volatile and alot easier on your combustion chambers sealing areas. less hard on the motor in general
Old Jul 8, 2010 | 02:22 PM
94BlazerPA's Avatar
I checked the OBD and I dont have any codes stored, the Light wasnt on, but I figure I would check anyway. It just kept flashing 12. Probably going to get a new pump this weekend and replace that and see what happens.
I should go to NAPA and get a AC Delco replacement part right, not a Autozone or Pep Boys brand?
Old Jul 8, 2010 | 02:34 PM
ohsofly's Avatar
Get the Delco for sure. it wont be that much more. Ive gotta get myself a pump too on the way home from work tomorrow. Lets compare what we get them for. I got to a canadian NAPA store to get all my stuff.
Old Jul 8, 2010 | 09:34 PM
94BlazerPA's Avatar
alright I'll let you know. Are you going to do the exchange rate, I'm not good at math.
Uncle Buck
Aug 7, 2012 12:48 PM
Brilen33
Dec 1, 2011 02:07 PM
RolingKCBlazer
Oct 11, 2008 05:11 PM
Unlimitedsp
15
Feb 4, 2008 04:44 PM
vmx120
Sep 12, 2005 07:10 PM
