Stuck!!!
Hey. Im replacing the fuel filter o my 91 blazer 4wd. when replacing the filter....comon sense should say that i need to turn the nut on the line counter close wise. i already have loosened off the back end but for the front this just isnt the case. any ideas? i thought about trying to soak it with some wd-40 because i have limited access to rust removal products.
Im not sure what else to do. some help would be great. thanks |
RE: Stuck!!!
Sounds like you're doing it the right way. It's just tight.
RE: Stuck!!!
Mine was the same, factory filter. Its just rusted on probably. Soak it in WD-40 then go make a sandwich and watch some tv. Go back out and it oughta be good to go.
RE: Stuck!!!
It isn't left handed threads so as everyone has already said, you are turning it the correct way. I'll follow along with the recommendation of some penetrating oil and a beer or 3.
RE: Stuck!!!
This is one of those situations where heat would not be a good idea. Mine was a little tough to change as well.
RE: Stuck!!!
ORIGINAL: Blazin_Jason This is one of those situations where heat would not be a good idea. Mine was a little tough to change as well. You Would be suprised what years of experince would do....not a smart idea i agree but possible. I mentioned that to my dad being a mechanic of 18 years he knew the risks and was going to use it as a last resort. Fortunatly that was not the case and we managed to change it out. Thanks for the Help guys. |
RE: Stuck!!!
what finally got it unseized? Good idea to post results for searches and future members.
fyi i had a seized bolt for the starter, a lead pipe for leverage helped out alot. |
