Stuck!!!
Old Apr 6, 2008 | 12:15 PM
Blazer_boy's Avatar
Blazer_boy is an unknown quantity at this point
Default Stuck!!!
Hey. Im replacing the fuel filter o my 91 blazer 4wd. when replacing the filter....comon sense should say that i need to turn the nut on the line counter close wise. i already have loosened off the back end but for the front this just isnt the case. any ideas? i thought about trying to soak it with some wd-40 because i have limited access to rust removal products.
Im not sure what else to do. some help would be great. thanks
Old Apr 6, 2008 | 12:44 PM
Chevy Lover's Avatar
Default RE: Stuck!!!
Sounds like you're doing it the right way. It's just tight.
Old Apr 6, 2008 | 01:10 PM
86S10's Avatar
86S10 is an unknown quantity at this point
Mine was the same, factory filter. Its just rusted on probably. Soak it in WD-40 then go make a sandwich and watch some tv. Go back out and it oughta be good to go.
Old Apr 6, 2008 | 03:55 PM
It isn't left handed threads so as everyone has already said, you are turning it the correct way. I'll follow along with the recommendation of some penetrating oil and a beer or 3.
Old Apr 6, 2008 | 09:02 PM
Blazin_Jason's Avatar
This is one of those situations where heat would not be a good idea. Mine was a little tough to change as well.
Old Apr 10, 2008 | 01:07 AM
Blazer_boy's Avatar
ORIGINAL: Blazin_Jason
You Would be suprised what years of experince would do....not a smart idea i agree but possible.
I mentioned that to my dad being a mechanic of 18 years he knew the risks and was going to use it as a last resort.
Fortunatly that was not the case and we managed to change it out.
Thanks for the Help guys.
Old Apr 10, 2008 | 01:24 AM
curse's Avatar
curse is an unknown quantity at this point
what finally got it unseized? Good idea to post results for searches and future members.
fyi i had a seized bolt for the starter, a lead pipe for leverage helped out alot.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
Takila Sunrise
May 25, 2006 11:40 PM
jwm1676
Engine & Internal
Jan 12, 2005 12:50 AM
