Stumped
Old Apr 10, 2008 | 05:19 PM
bruce1157's Avatar
bruce1157 is an unknown quantity at this point
Default Stumped
My 92 s-10 Blazer will start, idles Ok, but will not accelerate. Any additional push on the gas pedal makes the engine buck and cough and hesitate/stumble. I've replaced almost all of the electrical side and I've got good spark. When I put a gauge on the fuel pressure port and turn the switch to on, the pressure goes straight up to 60 psi and then drops almost immediately to 20 psi. It sounds like a leak somewhere (fuel pressure regulator?). Anyone have any suggestions? Thanks.
Old Apr 10, 2008 | 05:39 PM
94blueknight's Avatar
94blueknight is on a distinguished road
Default RE: Stumped
have u checked ur spark plugs? i would start there cuz if the regulator is bad u will notice one bank is fueled out and that would be the side it is leaking.
Old Apr 10, 2008 | 06:08 PM
smokincivic98's Avatar
smokincivic98 is an unknown quantity at this point
Default RE: Stumped
could be a few things fuel pump, fuel filter, or my fav the spider unit
Old Apr 10, 2008 | 07:05 PM
Default RE: Stumped
Definitely sounds like you have a FPR leak. I would remove the cover on the top of the engine, then remove the MTV (manifold tuning valve) and have a look down inside of the intake. If you see puddles of fuel, you have found your leak. Follow the replacement How-To in the DIY section.
Old Apr 11, 2008 | 10:22 AM
bruce1157's Avatar
Default RE: Stumped
Thanks, guys, I'll give it a look this weekend. I did try a new fuel filter at the suggestion of a friend at work (what a job that was, rusted fittings and one was cross threaded by the last person that changed the filter) but it didn't seem to help. At least I know that it isn't the problem.
Thanks again.
youngbloodsno111
Mar 23, 2019 07:00 AM
black99gm
Oct 31, 2009 06:13 PM
Joey P.
Dec 21, 2006 09:23 PM
pinkituscaderro
Jul 5, 2006 04:28 AM
94_4.3dago
29
Feb 8, 2006 07:21 PM
