Is this supposed to be connected?
Old Jun 6, 2009 | 02:57 PM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
Default Is this supposed to be connected?
Ok, what is this, and why isn't it connected to something? The end seems too clean to have been like that since new and the end is bulged a little at the end as if a plug were in it.
I've been having idle problems with my blazer for awhile and everyone keeps telling me to check the vac hoses, well i went out and did that today and found this one. I have no idea what it is or where it goes. any help is much appreciated!
Old Jun 6, 2009 | 03:31 PM
oisinirish's Avatar
That appears to be the hose to your PCV valve?
Is there a diagram under the hood?
Old Jun 6, 2009 | 03:44 PM
ahhh, yes thank you much! There was a little diagram that had it labeled as PCV air in and it was showed connected to the air box. I found the little outlet and plugged it back in. Should that have a clamp on it? or just leave it free? And i don't suppose that would have anything to do with my crappy idle?
Old Jun 6, 2009 | 03:46 PM
oisinirish's Avatar
Definitely affects idle. You had a major vacuum leak with that disconnected.
How tight does is fit to the fitting on the air box? If it's pretty snug should be fine.
Old Jun 6, 2009 | 04:31 PM
How much does that affect idle? Would it cause the rpm's to drop when i shift into gear? because that's what i'm experiencing. I drove it after i connected it and it didn't seem to make too much of a difference. I'll go start it up and let it run in the driveway. Before i connected it, i ran it and the engine rpms would rise and drop constantly so i could watch the engine shake and vibrate pretty good. I didn't let it idle and watch it after i connected it though. i should have done that.
Old Jun 6, 2009 | 04:37 PM
oisinirish's Avatar
RPM's will drop when you shift into gear. That's normal. (Assuming you're not stalling.) While you're at it you may want to go ahead and replace that PCV valve if it's been awhile....they're like $4.00.
Old Jun 6, 2009 | 04:43 PM
well, see that's the thing, it drops almost low enough to stall. it makes the truck shake and then usually go back up. I went out and ran it, and it idled fine in park and while in drive. given, it's warm now. That may make a difference but the stalling seems to be random at best.
Edit: and i'll look into replacing that valve. Although im sure the shop i brought it to a few months ago would've checked that to make sure it was fine.
gpeebles
May 5, 2011 10:08 AM
Trizney
Mar 10, 2011 08:05 AM
puckrocker
Mar 2, 2011 02:01 PM
ty.justin
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jan 10, 2010 06:37 PM
Big Frost
May 13, 2008 03:36 AM
