surging idle
Old Dec 22, 2012 | 07:20 AM
blueblazer1969's Avatar
blueblazer1969 is on a distinguished road
Default surging idle
I got my blazer running I thought I had it.right now it has a surging idle and tries to die when you its a 2.8 1988 blazer its throwing a code 34 and 42 any advice on where to start or what could be causing this
Old Dec 23, 2012 | 08:06 AM
I reset the computer now I only get the code 42 this thing will sit and idle in park all day but when you put it in gear and take off when come up to a stop.sign it will die every time
Old Dec 23, 2012 | 09:04 AM
99cbsuv's Avatar
99cbsuv is an unknown quantity at this point
Either your timing is off a little bit ( turn distributor to advance a bit ) or you have a vacuum leak. If turning the distributor and checking timing does not solve your issue, then mix up a spray bottle of soapy water and check for a vacuum leak.
Old Dec 23, 2012 | 04:09 PM
i will check timing tomorrow thanks for the help
Old Dec 23, 2012 | 07:13 PM
ohsofly's Avatar
UnknownFish
22
Nov 14, 2011 07:40 AM
turquoiseblazer
Apr 24, 2011 10:53 AM
GeeWhiz
Feb 12, 2009 03:52 PM
smokincivic98
Jul 28, 2008 12:20 PM
wildboar
May 29, 2006 04:35 AM
