Swap cruise control switch
Old May 14, 2008 | 11:48 AM
ebornand's Avatar
ebornand is an unknown quantity at this point
Default Swap cruise control switch
I have a 1991 Chevy Blazer and the cruise control switch wrong and must change. My question is if someone knows how to remove the cruise control and placed the new. Thanks![/align]
Old May 14, 2008 | 03:05 PM
obso's Avatar
obso is an unknown quantity at this point
Default RE: Swap cruise control switch
You should be able to rotate the whole stalk (not just the part for the wipers) clockwise or ccw just a few degrees. Then it just clides strait out. You'll have to unplug the harness for it down under the steering column then installation of the new one is just the reverse.
Old May 15, 2008 | 07:13 AM
ebornand's Avatar
I try to do it but I do not...[/align]
Old May 15, 2008 | 07:39 AM
mr.vls's Avatar
When i did mine once the stalk was loose and unplugged I tied a string to the wire as I pulled it out of the column. That way I was able to pull the new wire through the column with the string.
88jimmah
Oct 11, 2007 08:11 PM
982DRBlack
Jun 27, 2007 06:39 PM
6wraith
Jun 27, 2007 12:44 PM
rjar5
May 1, 2007 10:11 PM
drefda
Jun 13, 2006 01:31 PM
