Temp. Switch ?? 4.3L vortec '93 Bravada
Old Oct 17, 2010 | 07:40 PM
BC1's Avatar
BC1
BC1 is on a distinguished road
Question Temp. Switch ?? 4.3L vortec '93 Bravada
The parts stores do not seem to be able to find in their computer files what I think is a temp switch on the head -- definatly threads into the water jacket--between cly 3 / 5 above the exhaust manifold. Can anyone here help me out with the proper terminology or part number?
Thanks in advance Bob
Old Oct 18, 2010 | 04:26 AM
Magmotor's Avatar
Magmotor is on a distinguished road
What your looking at is the Knock Sensor. Orielly #2KS28
Old Nov 18, 2010 | 09:39 PM
lovemybustedblazer's Avatar
lovemybustedblazer is on a distinguished road
Your temp switch, or coolent temp sending unit should be located right under and left of your thermostat.
Old Nov 21, 2010 | 08:12 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
its a coolent temp sensor on the passenger side of block
Old Nov 23, 2010 | 09:39 AM
Kainon's Avatar
Kainon is on a distinguished road
there's a technical difference when asking for parts,
Coolant temp switch would either turn on elec fan or warning light
Temp "sensors" will provide scaled info to the ECM and Gauge
not sure but i think the one at the thermostat outlet is typically for the ECM(could be 2 - 1 for ECM 1 for Gauge),
the one on the head could be a switch for the light ( used to be that way on older GM's)
knock sensors are under the head, screwed into a blocked hole in the side of the block usually opposite of the starter (LH/Drivers Side) where the middle crank bearing boss is, some engines may have 2
hope this helps,
I need to get my gauge working too
Old Nov 23, 2010 | 12:16 PM
mr.vls's Avatar
It is the coolant sensor for the temp gage/light.
zakm0n
Jan 9, 2011 07:31 PM
mboehler
Jan 16, 2009 07:16 AM
bertrenolds
Dec 19, 2008 07:45 PM
DaddyCop03
May 11, 2008 09:07 PM
naf821
Aug 8, 2007 07:19 AM
