Tensioner Pulley
Old Feb 15, 2019 | 10:21 AM
Lefet's Avatar
Lefet is on a distinguished road
Default Tensioner Pulley
The bottom nut
The pulley to the left
Geez, that looks bad no?
Yesterday, while driving home, steering got tight, battery light came on, thankfully was able to drive home, (which wasn't VERY far). Got home, a little smoke from the engine, opened hood, immediately found serpentine belt (replaced less than a year ago) broken. Upon further inspection found tensioner pulley a little snug. Today, took it off and it appears the bearings are bad. Now, my question is, do I have to replace the entire thing or just the pulley? I'm having a hard time getting that nut off and that's also the nut you use to release tension to change the belt. (Sorry for the slightly blurry pictures). It is the 1994 S10 Blazer Tahoe, 4.3L V6 OHV12V with the "W" in the VIN.
File Type: zip
Old Feb 15, 2019 | 11:20 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
New should come as an entire unit
Old Feb 15, 2019 | 11:39 AM
cleburne red's Avatar
Yeah, just replace the whole thing. It's not too expensive and easy to put on
Old Feb 15, 2019 | 11:48 AM
odat's Avatar
Old Feb 15, 2019 | 12:23 PM
Lefet's Avatar
Thanks.
They just don't sell the whole thing around me, just the pulley. Would have to order one online. (Live in the PA mountains/boondocks). Then I wouldn't get it until next week, fish out of water until then. Seems like I may not have a choice.
Old Feb 15, 2019 | 01:05 PM
CWBDDSPC's Avatar
Hmmmmm, local bone yard have one you could pull and use in the meantime? Otherwise, soak that puppy in your favorite Pb blaster, liquid wrench, ATF/acetone penetrate of choice and keep trying to remove the pulley. I’d still order a whole new one though...
Old Feb 16, 2019 | 08:18 AM
Lefet's Avatar
So it IS suppose to come off. Really just wanted to know if I was wasting my time trying to unloosen something that wasn't suppose to be loose.
Thanks
Old Feb 16, 2019 | 10:10 AM
CWBDDSPC's Avatar
It’s possible to remove yes.... supposed to be removed, well depends on how corroded the bolt is!!
Old Feb 16, 2019 | 01:13 PM
Lefet's Avatar
So, new tensioner and belt. All good to go and back on the road. Thanks for all the help!
Old Feb 16, 2019 | 05:38 PM
CWBDDSPC's Avatar
Good work!!
