timing marks/balancer Top Dead Center
Old Mar 25, 2009 | 08:41 PM
thehustler211's Avatar
thehustler211 is an unknown quantity at this point
Default timing marks/balancer Top Dead Center
Im trying to figure this out. When my timing marks are lined right up on the timing chain sprockets the key hole on the crankshaft points to 0 on the timing tab like it is supposed to but there is no line on the balancer where zero is. There are 2 lines but neither one is even close to where 0 is. I know one is compression stroke and one is timing but it makes no sense neither one is on the crank at zero . Should i just mark a line for zero on the balancer and forget the other lines? i need to get this thing timed
Attached Thumbnails timing marks/balancer Top Dead Center-timing.jpg
Old Mar 26, 2009 | 07:56 AM
Does the crank gear have multiple key way slots?
Please put your vehicle information in your signature...
Old Mar 26, 2009 | 11:15 AM
no there is just one key hole slot its weird we are confused trying to get this thing back together and on time. thanks
Old Mar 30, 2009 | 10:28 PM
figured it out the middle of the balancer was turning at the ruber ring.
Old Mar 31, 2009 | 12:43 PM
That's not good.
Old Apr 1, 2009 | 04:35 AM
Default balancer
not good?yeah i tore the whole truck apart did the timingchain and made my own mark on the balancer with a file and timed it. It seemed to be almost deadon time but afterdriving all day it still bogs everyonce in a while. Ithink that balancermight be turning agai. Any suggestions on whereto get a new balancer is this something i should get from the junk yard? does this happen often? anyoneever heardof this happening???? again the inside of the balancer is obviously turning on the inside where the ruber ring is because the TBC mark on the outsideof the balancer is moving. alsobout to do a new distributer. Could a bad distributer cause the balancer to shift? I hate/ LOVEthis blazer but damn im learning alot fixing this thing.
Old Apr 1, 2009 | 03:30 PM
I would not bother messing with a used balancer. Just get a new one.
kennycraze
Apr 5, 2014 05:55 AM
bertrenolds
Nov 25, 2011 08:51 PM
kyle45
Mar 31, 2011 09:59 AM
picinisco
Oct 28, 2008 01:52 PM
nelson 710
Oct 14, 2008 07:59 PM
