Quick question about Top Dead Center (TDC)...
Old Mar 30, 2011 | 08:44 PM
kyle45's Avatar
kyle45 is on a distinguished road
Default Quick question about Top Dead Center (TDC)...
I found the EDI timing instructions through a search and I am just curious if piston #1 is always in the TDC position when the alignment notches on the Crankshaft Balancer are aligned with the markers on the Engine Front cover?
I guess, this is also asking, is one rotation of the Crankshaft Balancer equal to all the pistons firing once?
Also, if the Crankshaft Balancer notches align up with the Engine Front Cover, but the distributor is out of place (according to the diagram), will the car be out of time? If so, how is that fixed?
Thanks.
Edit: This is what I am referencing: https://blazerforum.com/forum/tech-a...-timing-24373/
Old Mar 31, 2011 | 06:04 AM
The piston will be near, not directly on, TDC #1 when both timing marks are aligned. What you have to determine is that it is on TDC on the compression stroke (ie both valves closed.
Being a 4-stroke engine, it takes 2 rotations of the crankshaft to fire all of the cylinders. You can have the #1 piston at TDC on compression or exhaust strokes.
Old Mar 31, 2011 | 09:49 AM
kyle45's Avatar
What is the best way to determine TDC, on the compression stroke, for piston #1, if those marks only align for timing 50% of the time? -- just try both?
Thanks.
Old Mar 31, 2011 | 09:59 AM
Google "how to determine TDC #1 compression"
Many links for your viewing/reading pleasure.
matthewp
Apr 4, 2021 09:16 PM
kennycraze
Apr 5, 2014 05:55 AM
thehustler211
Apr 1, 2009 03:30 PM
nelson 710
Oct 14, 2008 07:59 PM
rriddle3
Aug 26, 2007 04:38 PM
