torque converter ?
Old Jan 16, 2013 | 06:57 PM
blueblazer1969's Avatar
blueblazer1969 is on a distinguished road
Default torque converter ?
what are the symptoms of a faulty torque converter lock up switch.
Old Jan 17, 2013 | 09:03 AM
Anybody got any ido on this
Old Jan 17, 2013 | 09:50 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
I think your truck would hesitate before moving if you had a problem with the torque converter not to mention you can feel when your tc locksup or comes out of that mode.
What symtoms do you have?
Old Jan 17, 2013 | 07:13 PM
at first it would drop in and out ofoverdrive now it wont go into overdrive it shifts into the rest of the gears fine fluid is fine im trying to eliminate everything besides the tranny
Old Jan 18, 2013 | 01:16 PM
I would change the 1st and 2cnd gear shift cylinoids.Could also be the actuator piston thats on the side of the trans.What is the fluid like red or dirty.
Old Jan 19, 2013 | 07:42 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
torque converter lockup failure will not be felt if it is stuck unlocked. it occurs in overdrive. if stuck locked it will stall your truck. When solenoids fail you get either 1st and 4th gear only or 2nd and 3rd gear only. If your only missing 4th you can try changing your filter but It's most likely your trans is on its way out
Old Jan 20, 2013 | 05:17 PM
I think if you read up on this there are sveral write ups on the forum,by doing a search you will find them.
killallblue
Oct 27, 2009 02:14 PM
Shaymus
Aug 1, 2007 07:20 PM
blackhole79
Sep 4, 2006 01:40 AM
Canadian88
Feb 13, 2006 04:04 PM
blazerrick
14
Dec 28, 2005 09:07 PM
