Transmission filter
Old Oct 25, 2015 | 12:39 PM
WLB's Avatar
WLB
WLB is an unknown quantity at this point
Default Transmission filter
I'm fairly certain that the transmission filter needs changed on my 94 S10 Blazer 4 by 4. The first morning it was below freezing it struggled to back up and then simply quit backing up. Went forward ok. I drove it around the block to warm it up and reverse worked. My question is: the parts store shows filters for deep and shallow pans. Anyone know the depth dimensions of the two pans?
Thanks
Bill
Old Oct 25, 2015 | 09:28 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Old Oct 26, 2015 | 05:31 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
Thanks
Bill
I can give you a hand on this.Not sure what type of tranny you have.But if it`s the 4L60E ?It has to sizes.2 1/4 for the normal smaller pan.The other size is what you call deep pan is 2 7/8.I have a 2001 LS Blazer with the overdrive 4l60e which has the deep pan 2 7/8.The pan is 2 1/4 infront (facing the engine) then it increases into 2 7/8.It`s actually 3 " but they call it 2 7/8.Look up (Summit racing .com) they have alot of name brand options to choose from.Not just crappy Ac Delco crap.
Old Oct 26, 2015 | 11:02 AM
The tranny should have a small 2x1/2" aluminium tag with numbers on it.
This should identify the tranny beyond doubt.
While I think that the 94 4x4 only comes with the one type of 4L60E Toocute350 has mentioned.
Old Oct 26, 2015 | 05:41 PM
josh18657's Avatar
josh18657 is on a distinguished road
I just bought both, compared them to the one I took out and returned the other one. On my 2001 it ended up being the shallow filter.
Old Dec 1, 2015 | 07:23 PM
brain7734's Avatar
brain7734 is on a distinguished road
You have a 4L60E trans and it's a shallow pan filter. Shallow filter body is about 1" thick, and the deep filter body is about 2" thick. The 4L60E went to the deep pan about '97.
surferman08
Oct 15, 2009 10:59 AM
GMC_Jimmy_13
May 4, 2009 01:43 AM
Ugly_Monkey
Feb 25, 2009 09:02 PM
Invisible Pedestrian
Feb 16, 2009 09:09 AM
capt703
Dec 1, 2005 02:17 AM
