Trouble Starting when hott
Old Jul 25, 2011 | 11:20 PM
tbcfreerider's Avatar
tbcfreerider is on a distinguished road
Default Trouble Starting when hott
Hello again. I love my 93 s-10 blazer 4x4 4.3l v6 vortec but its killing me.
I have noticed, when I start the truck I get about 10 sec of white smoke out the pipes then it goes away... (oil into valves?) so I'm trying to fix that and then as of recently after a decent drive i park, go do something and comeback within 1 hr and the truck has a hard time starting... it cranks like a 1/4 turn then acts like a dead battery. (vapor lock?) because sometimes it will start with in 3 cranks and others like today it took almost 30 min of sitting before it would start. I have also noticed that my engine gets insanely hot, even tho my thermostat in the dash tops off at 200. could it be bad? also my batter cables are too hot to touch. any advice, help, repair videos are welcome, I thank you all greatly in advance.
Johnny
Old Jul 26, 2011 | 12:03 AM
White smoke is indicative of coolant in the engine turning to steam. Oil is typically a blue smoke. From the sounds of it, you may have a head gasket leak or, more likely, a blown lower intake manifold gasket that is allowing the engine to ingest coolant.
Old Jul 26, 2011 | 12:59 AM
So I think Ive had the upper part of the manifold off before (I replaced the Spider) so do I have to remove all of that to get to the lower? then do i have to remove the valve covers? and replace the seals, and something with springs?
Old Jul 26, 2011 | 01:16 AM
You have to remove the upper plenum to get to the bolts that hold the lower intake manifold to the heads. To check the cooling system integrity, you can do a pressure test where you pump up the pressure in the system and monitor it over time. 16psi is the pressure that the radiator cap should maintain the system at and I wouldn't recommend going over that.
You can run a compression test to see if there is a potential head gasket problem. Looking at the plugs will also tell you if you have a coolant leak or compression problem on a particular cylinder. Water/coolant in a cylinder usually results in the spark plug looking steam cleaned, nice & white.
As I said, burning oil in the combustion chamber will typically result in a blue smoke. If the smoke is more blue, it could be due to valve seals.
Old Jul 26, 2011 | 01:20 AM
ohsofly's Avatar
Yes, the spider mounts into the lower intake, so you have to take all that apart, and then remove the lower intake. you can leave the spider on the intake to remove it, but I would take the spider off so you can clean the intake surfaces really well without damaging the spider. No, you dont have to remove the valve covers to do the job.
Old Jul 26, 2011 | 01:56 AM
Thanks guys... sounds simple enough... By chance do you know how many bolts I should be looking for to get the lower intake off?
Old Jul 26, 2011 | 06:55 AM
I'm not sure I would recommend the removal of the spider. Any movement in the 'nut kit' or internal fuel lines that run from the back of the lower intake to the spider and they tend to leak. Unless they are nearly new, I wouldn't mess with things in there. You can pull the poppet nozzles out of their respective bores in the lower intake manifold if you must so as not to damage them while cleaning up the gasket surfaces, but that is as far as I would go.
Old Jul 27, 2011 | 01:11 AM
@ swartlkk
you said: " a blown lower intake manifold that is allowing the engine to ingest coolant. " did you mean its cracked? or a bad seal? also as of today she REAKS of exhaust fumes... also do you think my starting issues could be due to this as well as the extreme engine temp? anain my dash doesnt ever go over half way(200f) Thanks again.
oh and where the heck can I get a lower intake manifold? Im looking Everywhere with no luck...
Last edited by swartlkk; Jul 27, 2011 at 06:52 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Jul 27, 2011 | 02:50 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
If coolant is leaking into the pistons that will cause a starting issue, vapor lock like you said. You can also see if coolant is leaking somewhere by checking the coolant level, if it's low then u probably have a leak. And the over heating part, i would think if the coolant is leaking through the head gasket not as much coolant would get back to the radiator to cool the engine. Atleast all that is what I have read on other posts. If I am wrong someone please correct me.
Old Jul 27, 2011 | 06:50 AM
Originally Posted by tbcfreerider
@ swartlkk
Should say gasket in there; as in lower intake manifold gasket. I have corrected my post. I posted that from my phone and it has been having trouble correcting text in that it sometimes over deletes and I must not have noticed it this time.
