used parts
Old Nov 23, 2009 | 09:55 PM
conrad Kuckes's Avatar
conrad Kuckes is on a distinguished road
Default used parts
hi i am a new member from minnisota. my truck is a 93 s10 4.3 with cpi.I been thinking of putting arear mounted turbo in, made with almost all used parts. anyone have any ideas?thanks.
Old Nov 23, 2009 | 11:53 PM
foxxie's Avatar
Welcome! from the wild west coast of New Zealand.
Old Nov 24, 2009 | 12:30 AM
kiwiblazer's Avatar
None at all, but welcome from New Zealand anyway.
Old Nov 24, 2009 | 12:41 AM
okvortec's Avatar
Welcome.
A turbo set up is going to be very time consuming and expensive. I wouldn't recommend used parts either. Try running a quick search, I bet you'll get some good info.
Old Nov 24, 2009 | 01:46 AM
ABN31B's Avatar
i'm with kiwi in that i can't answer that one.
i'm also with okvortec in that if you are going to do something like a turbo, go new. even a cheap set up from e-bay is better.
Welcome to the forum
Old Nov 24, 2009 | 05:50 AM
Sisk's Avatar
Welcome to the forum from Canada!
Btw..it's "Minnesota"...
Old Nov 24, 2009 | 08:05 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
I think it would be easier to just go and buy a nice used Syclone/Typhoon than try to cobble one together. You can find them on EBAY. Or you might find one locally.
Old Nov 24, 2009 | 08:51 AM
C.Blazer's Avatar
C.Blazer is on a distinguished road
I dont know on just buying a Syclone or Typhoon, they are quite expensive. My friends dad has a 91 Syclone, one of like, 11 in Canada. They are so sweet.
Back on topic, another welcome from Canada.
On the turbo topic, running a used turbo isnt all that bad, if you have the whole set up and you know it works, buying a used one online I wouldn't recommend. Also what made you decide to go with the rear mounted turbo? Or was it the obvious that they work better?
Old Nov 24, 2009 | 03:48 PM
thanks for the imformation.soon as i get a chance i am going to the bone yard and see what i can find.
Old Nov 24, 2009 | 10:45 PM
urbex's Avatar
urbex is on a distinguished road
I've used plenty of used turbos over the years, but only when I can pull them apart before purchase to verify that the turbine and compressor is in good shape. I routinely rebuild them with new bearings and seals before installation anyways, so I could almost care less about the condition of those parts before purchase (assuming they haven't seized and damaged the shaft, or are so wasted that the turbine/compressor has been rubbing against the housing). That said, I would never buy one sight unseen, including ebay.
As for installing it, while it _can_ be done, you would be looking at running a low pressure setup on an otherwise stock engine, and likely would be looking at minimal gains for the amount of work involved in getting a turbo in there. Other than the Syclone/Typoon exhaust manifolds, there's nothing else out there that will be a bolt on, or even close to bolt on setup for the exhaust plumbing to the turbo. If you don't want that setup, it will be full custom work. If you're not capable of fabricating it yourself, or have friends that are capable, it will cost a ton to have a shop do it for you.
Keep in mind you'll have to upgrade the fuel system, and have the computer reprogrammed to handle the addtional fuel flow, and be able to handle positive pressure on the sensors. Again - all custom work, and will be expensive whether you do it yourself or not. I'm not 100% sure, but pretty sure that even with the CPI system, the '93 is still using an ODB1 computer system, and does not have flash chips for easy reprogramming. You'll have to get an EEPROM programmer and the software, which was at least a couple hundred last time I checked. Not to mention the knowledge of what to change and how. Screw it up, and you'll blow the engine.
Ideally you'll want to rebuild the engine to be able to handle the boost, and that's money again, and not something you'd want to do with junkyard parts.
Quite honestly, unless you're hellbent on having a turbo'ed 4.3, you'd be far better ahead both financially speaking and power level speaking just to go V8.
tibby
Dec 26, 2011 08:22 AM
Crowley
Oct 12, 2010 07:40 AM
zcat23
Sep 29, 2010 10:30 AM
Jimmy_Boy
Apr 16, 2008 03:53 PM
lionel2
17
Feb 13, 2008 04:23 PM
