vaccuum line
Old May 4, 2010 | 07:32 AM
brett robinson's Avatar
brett robinson is on a distinguished road
Default vaccuum line
ive replaced some of the vacuum lines but i left one untouched....i dont know were it goes and i dont want to mess anything up..I do know that it goes down behind the back of the engine though...Im thinking it goes to the heater but not sure..any help someone....Its a 4.3L 6 cyl vortec...
Thanks
Old May 4, 2010 | 09:45 AM
The vacuum system is not all that complex on your truck (EVAP system aside). You will have a vacuum line running from the engine to the check valve/'t'. From there, it will run to the HVAC system (into the firewall), the vacuum reservoir (ball), and to the 4wd system (down to the transfer case) if so equiped.
Old May 4, 2010 | 09:58 PM
yea i have already change the one that goes to the vacuum reservoir and to the 4 whl drive system....basically all the ones that come from that check valve t....isn't that the little plastic piece that has like 3 or 4 vacuum lines coming from it????Ive changed all of them but the one going through the firewall....i just dont know if there is anything that i can mess up following it down there or something....cause i dont got the money to replace anything right now
Old May 5, 2010 | 03:15 PM
ohsofly's Avatar
It goes into the cab and controls your HOT/COLD door flap and selector switch for your in cab heat. Its up under the dash and might not be easily accesable but is doable.
Old May 5, 2010 | 06:11 PM
aight man thanks
PhilX
Oct 4, 2010 02:13 AM
Barc
Jan 26, 2009 07:07 PM
matclark
Oct 18, 2008 10:14 AM
matclark
Jun 30, 2008 02:24 AM
matclark
Jun 29, 2008 11:29 AM
