-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   What happened to my blazer? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/what-happened-my-blazer-9539/)
Gippy87 Mar 24, 2007 04:40 AM
I own a 1993 s10 blazer with the 4.3L vortec. Im pretty good with cars but have never had this hapened to me so maybe you guys can help me out. I was driving home and my car started making a winding noise sounded sorta like a power steering pump when u turn the wheel i didnt think to much of it but i checked it out sounded like it was coming from around te alty. I checked all my fluids and everythign seemed fine the noise went away after driving a little more then it started again then got worse and made a bunch of noise. all the sudden my engine just dies like it locked up or somthing, when i try and turn it overitturns about 1/4 a turnthen stops dead in its tracks when i let go of the key it just goes back to its original postion like there is somthign binding keeping it from turning over. Anyways i have no clue what this is and any help would be greatly appreciated.
SDimeBlazerlady Mar 24, 2007 05:17 AM
RE: What happened to my blazer?
spun a bearing maybe?[&:]
Gippy87 Mar 24, 2007 06:24 AM
i was thinking maybe one of the accessories froze up but i dont think the belt has enoug tension on it to stop a running motor i would thhink the belt would just slip on the frozen up pulley
Gippy87 Mar 25, 2007 12:18 AM
Nobody knows what this could be? I was driving at 35mph and the engine just shuts down. The starter engages when i try to start it but it cant turn it over, but its not like a dead battery issue where it doesnt have enough power. If it were my timing chain what are the chances my valves didnt get smashed by the pistons?
Chevy Lover Mar 25, 2007 03:45 AM
Is the battery fully charged or has it lost voltage?
Have you checked the oil and coolant level and condition?
When you try to start it does the positive battery cable get really hot?
You can also pull the spark plugs and try to turn it over (no compression to stop it), check for coolant in the cylinders.
Blasir Mar 25, 2007 11:05 PM
Remove your serpentine belt and see which pulley is frozen. You can try to start it with the belt off but if it starts, don't let it run too long because your water pump is not spinning either without the belt. Probably your AC compressor, Alternator or the belt tensioner pulley. There is also a dead pulley under the AC compressor.
88blackzcand95blazer Mar 29, 2007 05:23 AM
i doubt belt has enough tension too, sounds internal to me do what chevy lover said ^
jdt May 28, 2009 12:57 PM
the alt,can lock up and the starter can`t overpower it sometimes.remove the serpintine belt and see if the motor will then turn over.
91chevywt May 28, 2009 02:31 PM
The belt can stop a motor from turning over, it happened in my pickup. Alternator seized. It'll be easy to find if you take off the belt and check the accessories by hand.
swartlkk May 28, 2009 02:57 PM
Man I hope the OP fixed his truck by now...
