What should the oil pressure be on a 2.8L?
Old May 28, 2009 | 11:06 AM
muszyngr's Avatar
muszyngr is an unknown quantity at this point
Default What should the oil pressure be on a 2.8L?
Did a search could not find an answer so forgive me for asking if this was asked already. What should the oil pressure be on the 2.8 L? On my '97 Tahoe 5.7 L it's like at 60 psi on my '85 2.8 L Blazer it's at about 10 psi, that don't seem right?
Old May 28, 2009 | 11:46 AM
oisinirish's Avatar
From what I could find "Google Wise" should be around 40 ish.
Have you verified this oil pressure?
Old May 28, 2009 | 01:00 PM
Depends on the conditions. 10psi is on the low side should not be a problem if at idle, fully warmed up. You should see around a 10psi per 1000RPM over idle. So 20psi @ 1500-2000RPM, 30psi @ 2500-3000RPM. Comparing to another vehicle is really not valid. No two vehicles will have identical oil pressure as it depends on the fit of all of the parts in the engine, the accuracy of the factory gauge, and the age/health of the motor. Even new vehicles can have differing oil pressure readings by as much as 10psi.
trobbins
Jan 9, 2013 10:17 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
