why am i blowing rear brake cylinders
Old Apr 18, 2009 | 07:08 PM
marine1jpp's Avatar
marine1jpp is an unknown quantity at this point
Default why am i blowing rear brake cylinders
I have replaced a couple of left rear wheel brake cylinders. I just had to replace a porportinal valve and when i went to bleed the system another left rear cylinder is in pieces in my drum. The chance that i could be doing something wrong is at the top of my list so any help would be great.
Old Apr 19, 2009 | 07:19 PM
How are your brake shoes? If they are worn hard, they can allow too much travel in the wheel cylinder.
When you put everything back together, how much room is there between the shoes and the wheel cylinder?
Old Apr 22, 2009 | 02:19 PM
mr.vls's Avatar
Same thing if your drums were turned too much also If your shoes are not adjusted correctly and the self adjuster is not working, that could add to the problem.
Hank3band
Sep 20, 2011 09:08 AM
blazinloud
Jan 5, 2011 10:29 AM
Concerned
Apr 1, 2009 07:01 PM
hazzman52
Nov 10, 2008 10:45 AM
guillermoariast
Jan 26, 2007 05:26 PM
