-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Wire up push button start w/switch (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/wire-up-push-button-start-w-switch-15651/)
88jimmah Dec 24, 2007 05:53 PM
Recently my ignition became stuck in the "on" possition, and will not turn off.
I want to just bypass the ignition and hook up a toggle switch for the accessories and a push button for the starter.
I have never done this before and was hoping someone here has and could tell me what I need to do (in detail, if it isnt to much trouble), or could point me to a place that has the information I am looking for.
Thanks in advanced for any help/information!
hillbillyinOhio Dec 25, 2007 08:45 PM
RE: Wire up push button start w/switch
read this post, then ask if you have more questions.
http://www.the12volt.com/installbay/...h+button+start
DetroitMuscle Dec 26, 2007 05:29 PM
That might be helpful for a general overview of how to do it but it is a dodge and you got a chevy
hillbillyinOhio Dec 26, 2007 05:33 PM
what does it matter what car it is. Same thing for 99 percent of cars on the road.
Make sure you know what you are talking about before you make comments. lol
88jimmah Dec 28, 2007 08:54 PM
Well I was mainly looking for a how-to on how to do it to my jimmy :) I have the general idea on what needs to be done but the problem is I am not sure which wires or how to get to said wires.
My guess is that I have to take the steering wheel off and remove the old ignition which would reveal the wires needed.
Blazin_Jason Dec 28, 2007 09:03 PM
Remove the panels under the wheel so that you can have access to the main plugs on the column. Here is some information on what wires are there. It might help to loosen the 2 15mm (I think) nuts that hold the column up to get to the plugs.
88jimmah Dec 28, 2007 10:18 PM
Cool, thanks!
So this is what im guessing...
On the toggle switch I will have the following:
SIDEA: Accessory Orange wire
SIDEB:Constant 12V Red wire
And the following hooked to the push button:
SIDEA: Starter Yellow wire
SIDEA:Ignition Pink wire
I am not sure if I need to have a ground wire...and if so where does it need to be
Blazin_Jason Dec 28, 2007 10:52 PM
I'm trying to seach and see what to do. I would think that the ignition is going to have to be on with the toggle switch. The push button should only activate the starter.
88jimmah Dec 28, 2007 11:15 PM
Yea I think you are correct about that...when I first typed that reply I had that on the toggle switch but changed it.
Blazin_Jason Dec 28, 2007 11:21 PM
Couple sites here. 1 & 2
I'm thinking something like this. I've never done this before.
On the toggle switch:
SIDEA: Accessory & Ignition Orange wire & Pink wire
So when the switch is on, contact is made to activate and turn on the accessory and ignition.
So when the switch is pressed it cranks the starter.
I don't think you will need to ground. Now go out and try it =)
