Wiring
Old Mar 23, 2008 | 01:49 AM
JJ's Avatar
JJ
JJ is an unknown quantity at this point
Default Wiring
I have a 1984 s-10 Blazer that has a great body, but a worn out 2.8 V6. I purchased a 1991 s-10 Blazer with a 4.3 engine that has very low miles. What I would like to do, and theseare my questions.........
How difficult will it be to change the wiring harness from the 91 over to the 84?
Besides changing the fuel tanks, are there other pieces I'll need to make sure I take off the donor?
Is it that difficult to take the entire wiring harness and swap it over?
Old Mar 23, 2008 | 07:06 PM
Default RE: Wiring
You would need the transmission from the donor truck as well. The 2.8L v6 does not have the same transmission bell housing bolt pattern that the 4.3L v6 has.
As far as wiring change over... It may require both the engine and interior harnesses, but you would have to get wiring diagrams for both trucks to determine what the differences are. The biggest problem (wiring & controls wise) is you are going to be going from a carb'd motor to a TBI motor...
Old Mar 30, 2008 | 12:36 AM
JJ's Avatar
JJ
Default RE: Wiring
I'm changing the transfer case, transmission, and engine from the 91. According to the manual the engine and dash harnesses are totally different. I think I'm going to wind up taking the dash from the 91 as well. I guess I'll find out how much difference there is between the sheetmetal on an 84 and a 91 inside the cab.
Thank you for the reply
phxjosh
Oct 30, 2013 10:03 AM
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
joshzerofour
Feb 15, 2005 11:37 PM
chris
Dec 6, 2004 12:47 AM
