wont start
Old Jan 24, 2007 | 10:24 PM
midajahlynn's Avatar
midajahlynn is an unknown quantity at this point
Default wont start
i have a 93 v6 vortec and it codes 43,66,67,82 i do not know what to do please help
Old Jan 24, 2007 | 11:38 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: wont start
Did you check spark? Injector pulse? Fuel pressure? We need MORE INFO. Just because a vehicle has codes does not mean that is why it will not start. Code 43knock sensor circuit, 66, 67, 82 are all trans codes, none of these will cause a no start. So please let us know more info!! Not trying to ba an *** or anything, I'm here to help. Thanks, Korey.
Old Jan 27, 2007 | 12:54 AM
it has spark it started up fine then we went to start it 2hr later it whould not start so my bro in law tryed to jump it and nothing it makesno nosies dos not even try to turn over at all sorry for the no info frist time
Old Jan 27, 2007 | 01:06 AM
Kordog's Avatar
What does it do? Any noises, like a click or any thing? Try turning on the headlights, then try cranking. If the lights go out, check the battery cables. Actually remove them from the battery to check them. If they stay on while cranking, I would make sure the signal wire at the starter is getting power while cranking. If you have power there then replace the starter. You can however, try tapping, thats tapping on the starter with a hammer while a helper is trying to crank the engine. The key must be in the crank position while tapping on the starter or this will not work.. Good luck, Korey.
Old Jan 27, 2007 | 01:09 AM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
tapping the starter will at least get you to the parts store assuming that is the problem. From what you described it kinda sounds like that is the problem
Old Jan 27, 2007 | 01:15 AM
thank you guys i will check the starter when i get home from work thanks a hole lot
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
