yet another problem
Old Nov 11, 2008 | 03:12 PM
juan8w1's Avatar
juan8w1 is an unknown quantity at this point
Default yet another problem
ok guys where to begin? first i had a bad gas smell from the exhaust found i had a bad cpi spyder replaced it , after replacing the spyder i go to crank a truck i had been driving up until the gas smell problem . my wife turns the key and it spins a few times and stops . i look around and from what i guessed and others its the starter i go and get another starter replace it and oh snap .. its doing the same thing i notice that it whould try and crank but get to a cer tain point and lock down i mean you cant t run it which was making the starter appear to be bad you turn it by hand and get pass that certain place and it turns freely until it gets back to it and it locks up again ,,,, i am thinking i have turned an incert.... am i wrong or is this yet another regular blazer problem ... ??? how do you turn an incert over night and in your own front yard, and if this is something simple, and i did something wrongwhich is making it do this . i will donate 200.00 i just wont to drive my truck again any advice or comments please advise ???
Old Nov 11, 2008 | 03:18 PM
rriddle3's Avatar
Default RE: yet another problem
It was a little hard to folllow your post, but it sounds like you may have gotten enough fuel into one or more cylinders (if the spider was leaking badly) to lock the engine (liquids don't compress). Try removing the spark plugs one at a time and see if fuel comes out of any of the cylinders.
Old Nov 11, 2008 | 05:25 PM
No donations required! LOL
Definitely pull the plugs and see if the engine turns over freely on the starter. I am of the same opinion as Rich that you have filled one of the cylinders with fuel.
Do not forget to change your oil!
vetteandblazerman
Oct 29, 2009 03:57 PM
blazin_j
Oct 17, 2009 06:38 PM
igot10pinitis
Apr 16, 2009 08:06 PM
Good_Chevy
Nov 24, 2008 06:27 AM
metalhead
Aug 12, 2007 09:16 PM
