1999 4wd Blazer LT blows hot air all the time
Old 06-29-2015, 06:59 PM
FT III's Avatar
FT III is on a distinguished road
Default 1999 4wd Blazer LT blows hot air all the time
My blazer blows constant heat even when all settings are turned off.
It does not have the auto climate control, I have to use a manual dial with the blue and red colors for temperature control.
Can some one help me to root cause the problem so I can fix/replace components and stop having this condition?
I red in the web, that this might be a federal or safety regulation which sounds very strange for me.
Please advice,
FT III
Old 06-29-2015, 09:51 PM
Rottidog's Avatar
Could be a blend door issue. Check the vacuum lines under the hood & make sure they're all hooked up & not cracked. They get cracked & you lose the vacuum that is what makes the blend door move.
Try running the engine & spraying brake cleaner over the vacuum lines (don't be smoking when doing this lol). If the engine revs at any point, you've found a leak in the line.
j_o_s_h
08-28-2013 02:40 PM
danjdugan
05-14-2011 02:45 PM
sprbld417
08-29-2010 08:43 PM
66low
08-28-2009 05:16 PM
ravenhurst
15
04-26-2009 07:53 AM
Quick Reply: 1999 4wd Blazer LT blows hot air all the time
