2002 2dr. blazer problems starting
Hello all I'm new to the forum. So here is my problem. For about the last 3 months my blazer would not start on the first crank, but would always fire up the second crank. I ignored the issue because it runs perfect when started. So a couple of days ago the problem got worse. It takes about 7-8 cranks just to get the vehicle started. It's to the point that I'm running the battery dead before it starts. This morning I charged up the battery and cracked it over and over until I finally got it started. I took it for a drive around town and it run flawlessly, no stalling, no loss of power, nothing. My best guess is the fuel pump is not putting out enough PSI, but before I go spend $400-$500 to get the pump replaced I wanted to see if anyone else has had this problem and possible causes. Thanks for the help in advance.
2002 2Dr. 2WD Blazer LS
You're on the right track...check the fuel pressure and do the 96+ fuel system diagnoses available on this forum. Let us know what you find out.
cleaveley
04-01-2014 12:50 PM
brendan127
03-27-2013 05:37 PM
skygodtj
05-23-2012 09:08 PM
brendan127
11-01-2011 07:54 PM
