2003 Blazer s10
EDIT: I see BWD 63885 is for V8, is that correct? If so, then two rows, four pairs each. By the way, You may also check and compare the coil resistance in between the old MFI and the new one.
A great diagnostic tool is a set of needle point multimeter leads because you can push them into the back of a connector past the wire or pierce the wire itself leaving only a very small mostly self healing hole. If the wire is in a critical spot for moisture you can seal the hole with liquid electrical tape.
These are OK quality but they get the job done. You just cant get too aggressive because the lead metal is soft:
George
rockjock29bc
83
08-01-2019 07:26 PM
bertrenolds
01-12-2011 10:00 PM
