ABS light and Parking Brake light issue
Old 03-12-2018, 05:37 PM
Graveyard's Avatar
Graveyard is on a distinguished road
Alrighty, I installed the ground harness and back together. No ses lights and so far so good. can't hardly wait to drive it for the next few days!
Thanks so much
Old 03-12-2018, 06:40 PM
LannyL81's Avatar
LannyL81 is on a distinguished road
The problem is likely not the WSS, but cracked solder joint(s) on the ABS module, somewhat common. Probably easier for you to do a search on ABS to find the threads regarding how to remove the ABS module, and repair.
I did this to my '02, not difficult at all other than carefully getting the plastic cover off the electronics without breaking it. Also if you do not have soldering tools will need to find some one in your area to do it.
Good luck.
Old 03-13-2018, 09:16 AM
jacked_72's Avatar
jacked_72 is on a distinguished road
The 96 has a different ABS module than later years. Re-flowing the broken solder joints won't work on a 96 because you cannot get to the circuit board..
Old 03-13-2018, 06:12 PM
LannyL81's Avatar
Thanks jacked_72....been way too long since I had my '95 to remember anything about the ABS.
Old 03-14-2018, 08:47 PM
Graveyard's Avatar
Hey Jacked_72, It's been three days with a bunch of driving....it seems like all my issues have been resolved!!! Thanks so much!
Man, I have been chasing this problem for 2 years probably...lol or more.
Old 03-15-2018, 08:50 AM
jacked_72's Avatar
Glad it worked out. The solution was really 22 years in the making. Pass the word on this fix because you and me are about the only two people that know about it. My S10 is a low mileage truck (82K) and I have the car fax. Up until the truck had about 35K in mileage, it was in the shop three or four times to "check electrical system." After that, it appears they just gave up. I can't believe that GM didn't issue some sort of service campaign to address this problem, but that is the GM I've come to know and understand. My last GM was a 76 Vega! It took me until 2017 to be willing to try another.
Anyway congrats! I'm about 500 miles into my repair and I have not had a single problem. I do wish I could have the money back on all the parts and sensors I threw at it trying to fix the issue, but all's well that ends well.
Old 03-15-2018, 09:13 AM
Graveyard's Avatar
Heck, me too on the money and parts. I'm positive I changed a bunch of perfectly good parts. I'm sending you a pm.
Later
Old 03-15-2018, 10:53 PM
puttster's Avatar
puttster is on a distinguished road
Good luck.
Lanny, my abs light is back on. If i attempt a solder cure and mess up will i have damaged something that will make the brakes less effective than they are now?
Old 03-17-2018, 11:58 AM
pitt2943's Avatar
pitt2943 is on a distinguished road
Negative other than losing ABS which you don't have now anyway. This repair is not for the soldering novice. The part is called the EBCM. Electronic Brake Control Module. Made by Kelsey Hayes. You can buy repaired, upgraded ones on Ebay for like $60.
It's like 42 solders to undo then redo and they use a very high temp solder. They are VERY difficult to unsolder. I wouldn't even attempt it without solder wick. I've ruined probably 2 of 4 by burning out the through holes on the PCB before I figured out somebody was repairing them and selling them cheap, with a warranty. The 2 I did successfully did hold. The problem is the relay. It is on the underside of the board hence the 42 solders you have to undo to flip the board. Once to the relay, the 15A relay is usually replaced with a 20A. (amp)
jaatecart
07-16-2018 11:10 AM
ussexplorer
05-24-2017 06:00 AM
Amber Kay
12-22-2015 08:46 AM
beastbandit92
08-13-2010 08:24 PM
cide
08-09-2009 08:02 AM
Quick Reply: ABS light and Parking Brake light issue
