blazer bolt pattern and offset
Old Feb 13, 2011 | 09:25 PM
cartunez2004's Avatar
cartunez2004 is on a distinguished road
Default blazer bolt pattern and offset
im tryin to get rims for my truck and i cant remember what the offset is suppose to be i have a 98 jimmy 4x4, i looked them up and it said that bmw was the rite off set and i got a pair of 22s of a 745 bmw and they stick out in the front. so im sellin them and gettin different ones that wil fit the way there suppose to, i had a jimmy @ 4 years ago and rims were fine
thanks in advance
Old Feb 13, 2011 | 09:37 PM
TripleBlackBlazer's Avatar
Bolt pattern is 5 x 4.75. You will want around 6" of backspacing to stay within stock specs for the 4wd, less if you want the rims to stick out more. Also, check out tirerack to get a decent idea of offset as I'm not as familiar with that as I am backspacing.
After a quick search (on tirerack.com) it looks like offset is anywhere between 25mm and 50mm depending on the wheel.
Old Feb 13, 2011 | 09:41 PM
thats a big difference lol 25-50 thats like a low/mid offset, what do u mean it depends on the wheels
Old Feb 13, 2011 | 09:52 PM
25mm difference is less than an inch.
4wd backspacing is 6". That means that there is 6" of space between the inside lip of the rim and the mounting surface of the hub.
Offset is how far off from the center line of the rim the mounting surface of the hub is.
When I said "depending on the wheel" I was referring to the wheels listed on tirerack.com that will fit your truck. Some were as low as 25mm positive offset, some were as high as 50mm positive offset.
So your BMW rims may have had the right offset but the wrong backspacing, or the offset may have been wrong as well. Tirerack lists offset for the 22's at 18-21mm and backspacing around 5.8".
How far were they sticking out in front?
Old Feb 13, 2011 | 10:20 PM
they stuck out alot prob atleast 2inches
first pic is how they stick out pic kinda sux doesnt really show how much they really did stick out 2nd pic is my old jimmy and they stuck out maybe a half an inch and i had that dropped 3''
pomacanthus
Mar 26, 2014 09:06 PM
98 White Blazer
Tires and Wheels
Nov 14, 2011 06:31 PM
sporty_drew
Tires and Wheels
Aug 9, 2009 11:47 PM
AtreyuManiac
Tires and Wheels
Jan 4, 2008 07:58 PM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
