Cheap way to read Camshaft Retard
Connected to the vehicle.
* Connect/GM Powertrain/Full Auto Scan/OBDII/select the shown address
* Let software scan the available PIDs
* Save PIDlist to a filename of your choice.
I don't know how to make this any clearer.
I guess I did forget to state that when you go back in the house to build your gauges, you need to first:
* Connect/GM Powertrain/NoScan/IMportPIDs Offline/Import from file/select your PID file......... Then open dashboard. Now all the available PIDs should be under Available PIDs.
Hope this helps. If all else fails, PM me and we will go through it together on the telephone during an evening.
I think I am not sure where to select "GM powertrain" and "full auto scan", and where do I select the "address". Thanks for you fast reply I was trying to do this last night about midnight and that was part of my problem. I am going to try again tonight after I get home from work.
"Connect/GM Powertrain/Full Auto Scan/OBDII/select the shown address"
After it scans the Pids you should be able to save the PID file and the connect button should change to "connected".
After you have built your gauges, you save the gauge profile to a file and you can always easily recall it.
Ok I see the problem. Once I have plug in the BAFX OBD2 into the 'burb I turn the key on I search for bluetooth, and when it is sync'd I select connect at the bottom of the screen, and then I don't have the option "GM Powertrain" I only have choose device OBDII or import Pids (Offline)?
At this point I am wondering if Dash Command from Palmer Performance might be a better choice for 1996 Blazer GM extended PIDs. I believe they actually license them from the automakers. I wish I had a 1996 locally to check for you but unfortunately I don't. At this point I may have wasted your $8.95. Dash Command cost me $10 + $10 extra for the extended GM PIDs and it also does CMP retard on my 2001. If we can figure this out you could ask the developer of Car Gauge Pro to refund or fix and I would help support that (I have worked with him some). Would you be willing to try Dash Command at $20? Uses your BAFX adapter. Just trying to give you options.
Morning,
got my refund from pro gauge and purchased dash command and the gm pids. So now I can't seem to figure out how to add the cam retard offset gauge. All the other stuff seems to be working.
When I go into edit gauges, I can go into "general" and select the first setting which is cam retard. Then I select needle and name, so I have 3 lines that are set for the general cam retard. when I save, it always creates an rpm gauge.
Obviously I 'm not doing something right.
Thanks
Thanks
