Cyl #4 misfire
Old 07-12-2017, 03:47 PM
Justin56's Avatar
Justin56 is on a distinguished road
Default Cyl #4 misfire
I just picked up a 2000 Jimmy it has a miss on idle but smooths out under acceleration. I changed the cap rotor plugs and wires all ac delco parts. I found a couple bad wires from the set I took off. I still have the misfire at idle and today the #4 cyl misfire code came back. I'm thinking bad injector or spider seeing its the same cylinder everytime and only misfires at idle. This sound about right?
Old 07-12-2017, 04:01 PM
newguy's Avatar
I would pull the plug and and check the gap and condition first. Maybe even replace plug. Doubtfull but a while back I was chasing the same issue and the plug was loose
Old 07-12-2017, 04:03 PM
Justin56's Avatar
I already checked that. It was good to go.
Old 07-12-2017, 04:13 PM
newguy's Avatar
What doesnt make sense is its only at idle
Old 07-12-2017, 04:15 PM
Justin56's Avatar
I'm going to do a leak down test on it tomorrow
Old 07-12-2017, 04:22 PM
newguy's Avatar
good luck could also be a sticking injector
Old 07-13-2017, 01:09 PM
Justin16's Avatar
Justin16 is on a distinguished road
I did the leak down test it stayed above 55 for over 10 mins. I've checked and rechecked my plugs wires cap and rotor I'm confident its not that. Ill check the injector pulse with a noid light when I get home. I just about positive I have a injector spider issue.
Old 07-13-2017, 01:29 PM
newguy's Avatar
how come you went from justin 56 to justin 16?
Old 07-13-2017, 03:01 PM
Justin56's Avatar
I need to delete the Justin16 one I was gone for a while and had to create a new profile and just by luck I logged in with the right pw to my old one
Old 07-20-2017, 02:56 AM
GreenBlazer2002's Avatar
Default Same issue here. Did it turn out to be the injector?
I did all the same things and still have the misfire #4 code haunting me. Was it the injector?
Quick Reply: Cyl #4 misfire
