fogged windshield losing antifreeze
My son has a 1996 blazer. We bought it this spring. At that time I replaced the lower intake manifold gasket. It has been working fine since with no loss of antifreeze until recently. He said it started to fog the windows this week and there was a sweet smell. I checked and the rad fluid was low. I checked the oil and the level is good and doesn't look frothy. I topped up the rad and we went for a quick ride (about 2 minutes) and there was no heat blowing when we tried the defrost. Temp on the gauge was around 100. Any ideas? It was dark when I looked at it tonight but should have a chance to look at it tommorrow when the suns up.
P.S. We did install a new CD player this weekend past in place of the original radio/cassette player.
WC
WC
RE: fogged windshield losing antifreeze
What happens when the engine tries to get up to temp? If it only hit 100 in 2 min, that may or may not tell us anything.
sounds like the heater core is leaking.
X2 on the heater core. Good luck.
x3 on heater core. Its not the most difficult thing to replace, but is very time consuming.
Thanks I'll look for a write up unless someone has a link.
WC
WC
http://www.oplin.org/databases/proxy...ain.autorefctr
*Combining Consecutive Posts*
123456789 as card number
Select Cincinnati Library then select auto repair reference
Sorry for so many replies. When I try to put it into a single post, it wouldn't go through. Wierd!
*EDIT by swartlkk* - Combined consecutive posts. Forum is working somewhat properly again
