Fuel odor at start up
Old 08-14-2018, 09:12 AM
man0steel's Avatar
man0steel is on a distinguished road
Default Fuel odor at start up
My wife is complaining she smells gas every time I start my truck in the garage, if I have a window down I can smell it as well. I have check for leaks around the filler, canister, filter, and manifold connections and can't find anything. Doesn't seem to do it if I just cycle the pump. Should I just throw a canister at it and see or is there something else I should be looking for.
Old 08-14-2018, 10:25 AM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
Might also want to do the fuel pressure test to make sure that you don’t have leakdown when the truck sits causing it to be slightly flooded at start up.
George
Old 08-14-2018, 10:52 AM
man0steel's Avatar
Gosh I hope not......just did the LIM and injectors about 3 months ago. I will find my FI pressure gauge and see.
Old 08-14-2018, 11:51 AM
GeorgeLG's Avatar
I understand but this is a simple test that rules out half of the potential causes.
Another possibility is a faulty gas cap but that probably sets a code.
If not these things and you have checked for external leaks then it probably is the evap system. Finding line leaks is usually done with a smoke machine. If not that then the cannister itself or the solenoid(s). Topping off at the pump damages the cannister.
George
Old 08-19-2018, 02:52 PM
arick793's Avatar
arick793 is on a distinguished road
Is the check engine light on? My Jimmy had inconsistent raw fuel smells, with no actual fuel leaking. The last time I had the gas tank down, I broke off the nipple on top of the gas tank that attaches to a hose running to the evap canister
Old 08-20-2018, 09:25 AM
man0steel's Avatar
I was getting a CEL until I changed the fuel cap about 5 months ago. Since then no.
Old 08-21-2018, 07:18 AM
man0steel's Avatar
Found it, full blown fuel leak where someone cut the metal fuel line about three inches from the filter towards the pump and spliced it back with fuel line and hose clamps. So what is the proper repair for this? Can I get ferrule connectors and re-connect the lines or do I need to find a replacement fuel line.
Old 08-25-2018, 08:41 PM
Nola 77's Avatar
Nola 77 is on a distinguished road
I would replace the whole line 60 psi is too much to risk with gasoline and ferrule fittings
Old 08-26-2018, 08:39 PM
arick793's Avatar
Go to the help section of your auto parts store. You can buy high pressure vinyl fuel line hose, and metal to vinyl compression fittings. I've done many repairs this way and have never had a failure. Compression fittings are great for fuel lines but NEVER for brake line repairs.
Djs-Budman
03-20-2013 04:24 PM
kitkat1209
08-12-2012 01:54 PM
antman94
08-20-2011 12:22 PM
Haggus
06-25-2009 03:40 PM
sillycbr
06-07-2009 04:08 PM
Quick Reply: Fuel odor at start up
