Need help changing fuel pressure regulator
Old 11-13-2005, 12:52 PM
vifa84's Avatar
vifa84 is an unknown quantity at this point
Default Need help changing fuel pressure regulator
Hello,
I have a 99 blazer LT 4.3L with a hard starting problem. The plugs get carbon fouled, runs ok on highway idles a little rough. Everything I've read points to the fuel pressure regulator. I can't seem to find instructions on how to change it. Is it located inside the manifold? Do I have to remove the manifold to change it? Is there a fuel injection gasket kit i need to purchase? I'm not a pro, but I'm not scared to get my hands dirty either.
thanks
Old 07-07-2007, 01:58 PM
silverado is an unknown quantity at this point
Default RE: Need help changing fuel pressure regulator
I just recently replaced mine in a 2000 LS same motor. Its a little time consumming but not bad. The upper half of the manifold is plastic has about 9 bolts holding it on. the gasket is a o-ring type gasket and as long as evrything is clean you don't need to replace it. ( I didn't replace mine ) You will need to remove your throttle and cruise control cables to get them out of your way. the larg plug on the back/top of your intake is for your fuel injectors it has a clip to hold it on. when you go to slide the top off it will be a little tight around that plug area. just take your time and be gentle. the fuel pressure regulater is located on the back of the spider. hope this helps. Jim
Terje
11-04-2017 08:19 AM
57chevy
04-20-2006 01:16 PM
jr9880
02-08-2006 07:08 AM
jlinder
08-21-2005 11:08 AM
Quick Reply: Need help changing fuel pressure regulator
