New starter has "extra" terminal
Old Aug 7, 2014 | 11:51 AM
lilblazer's Avatar
lilblazer is on a distinguished road
Default New starter has "extra" terminal
I just recieved a new (rebuilt) starter from RockAuto and looking at the two side by side it looks exactly the same except on the back end there is a terminal stud with a nut on it. My other one doesn't. The rest of the terminals match up. It's off of a 2 door- 2000 Blazer 4.3. I checked the numbers for the one they sent and it checks out and all paperwork shows it's for my truck. Does anyone know what this "xtra" terminal might be for?
Old Aug 7, 2014 | 05:23 PM
Forist72's Avatar
Forist72 is on a distinguished road
Mine has that as well I think it might just be a ground... but not in use on mine.
Old Aug 7, 2014 | 08:19 PM
rexazz2's Avatar
you dont need to connect anything to it
It could be a switched positive or negative
I have a OTC test light that tells me if a circuit is positive or negative
OTC 3631 Heavy-Duty Logic Probe Tester - Test Light | Circuit Testers, Short Finders
Old Aug 7, 2014 | 09:00 PM
odat's Avatar
on old style selonids for the old style ing. systems the extra terminal was too throw 12 volts to the coil for a little hotter spark on starting as the coils only normally received 6 volts by a restive wire
Old Aug 8, 2014 | 07:54 AM
lilblazer's Avatar
Thanx for the replies- another question- when we put it on, there is about a 1/4" (or less)gap at the bottom of where it goes into the flywheel--is that right?? We didn't pay attention to the one we took out. Won't water and such get in there?
Old Aug 10, 2014 | 01:23 PM
rexazz2's Avatar
there is usually a small gap around the outside
nearly impossible to get all surfaces to mate
Sometimes you need to shim the starter away from the flywheel and that gap would make it possible
sifko36
Sep 26, 2008 11:45 PM
TT
May 6, 2008 06:49 AM
White00Blazer
Mar 9, 2007 05:18 PM
blazerscooby
May 3, 2006 11:25 AM
blazerscooby
Apr 17, 2006 10:53 PM
