Open Vacuum Line
Open Vacuum Line
I had to replace the short piece of vacuum line by the master cylinder at the tee that goes down to the line into the vacuum reservoir. My problem is I didn't notice if the line going off to the right was plugged into anything. It doesn't look like it was, and I can't find any ports it could have come off of. Is it just a vent or something? Thanks
Thanks guys. I finally found it. There's a nipple molded into the plastic panel (part of the vacuum canister?) under the ABS controller but it's recessed so the end of the nipple is flush with the panel. I would have never found it without loosening the ABS controller so I could nudge it out of the way a little. Even then I needed to use my inspection mirror to make sure what I thought I was feeling was the port.
Well, test drive tells me either that wasn't the right place or I have another leak somewhere. What started this was my service 4WD light would come on and I noticed it always seemed to do it when I moved the accelerator pedal, so I assumed it was vacuum related.
I have the NVG236 xfer case (RPO NP8) and I have replaced the actuator under the battery.
The vents take about 20 seconds to respond to a change.
Is there vacuum going to the NVG236 transfer case or is it completely electronic?
The vacuum line sounds like it is exactly where it is supposed to be. I had a problem with my 4wd not engaging and it was because that exact piece of hose wasn't connected to the little vacuum "ball" (not actually a ball i don't believe) in the fender
Thanks Maurer...at least I know I got rid of one variable.
I made sure all of that was good when I replaced the actuator...thx
chris015
02-14-2012 10:20 AM
