P0303 Only when warmed up
Old 08-20-2014, 01:29 PM
job247's Avatar
job247 is on a distinguished road
Default P0303 Only when warmed up
My 2004 blazer with 202,000 miles has a miss only after it is driven for about 10 miles and warmed up. I pulled each of the plug wires while it was running and had a miss on #3 cylinder so I done a tune-up with ac plugs, wires, distributer cap and rotor. Still have the same problem with a miss on #3 after it is warmed up. It runs great until it warms up then a miss. Was wondering if this could be a bad head gasket or possibly bad head or valve? I haven't done a compression check yet. Thanks for any help.
Old 08-20-2014, 01:38 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
have you ever replaced your injectors? i had mine replaced 150k, which was causing the misfire in cylinder 3 and 6. according to the "dealer" he said this is common around 150k
Old 08-20-2014, 02:40 PM
job247's Avatar
No. They have never been replaced as long as I have owned it and I bought it with 30xxx miles on it. Just curious, wouldn't it show a code for a bad injector? Was throwing me off as to why it only done it when it was driven a few miles but ran great when starting after it cooled off overnight...unless it may be a bad o-ring on the injector?? Thanks for the info though. It is definitely something I should check out.
Old 08-20-2014, 04:18 PM
burned's Avatar
burned is on a distinguished road
The 2004 has the newer MPFI system that is more reliable.
Do a compression test, you may have a valve problem.
Blade_24k
11-23-2021 01:36 PM
palmer96
07-29-2013 11:46 PM
97cherryblazer
05-19-2012 04:15 PM
96realwe
12-10-2010 09:19 AM
swarfel
06-16-2009 08:29 PM
Quick Reply: P0303 Only when warmed up
