quick spider injector question. please read!!
i just replaced spider injector about 2 months ago. i just pulled the top off again and there is fuel on FPR side near the front two popets or fuel lines. and their is fuel by the front popet/ fuel line on driver side. is their supossed to be rubber seals on the popets before i put them in??
I changed mine and don't remember it having any seals in the lower intake holes where the poppets went in when i got the new one it was the upgraded replacement with injectors where the poppets were and they didn't have seals either. are you sure yours clicked in all the way in?
Or maybe a crack in the plastic lines leading to the poppet.
yes i made sure they are seated properly. and if it had a cracked line i should have seen it dripping from one when i pressurized the system? im so lost and almost done with blazers for good. i pressurized the system several times with the plenum off and not one sign of anything leaking yet i have standing fuel??????
kevinph
02-25-2019 09:24 PM
wjtaylor
03-29-2012 06:03 PM
Paulpolar600
01-13-2012 08:39 PM
