Redoing LIM gaskets due to lack of RTV
So I have been having this strange issue on the way back from my trips when I'm going above 100km/h the vehicle develops a leak from back passenger side.
This leak then is dripping onto the exhaust and smokes pretty hard
At first I thought it was the valve cover but I'm pretty sure I have to redo the LIM gaskets.
So my question is..
Could I reuse them after less than 1000km? Or should I get new?
I only put RTV on the flat pieces but researching more it states to put some upwards as well...
So my question is..
So did I. Several times. With about no more than 5mm overlap to the gasket. No leaking experienced. Are You sure LIM has landed flat? Did You follow tightening procedure?
Is there a trick to getting it sit proper? I had a bit up problem lining up the gaskets since they kept sliding down. The 95 never got the updated gasket that sits in place
With regards to sitting the LIM, I've been following the 4.3 vortec manual - there are specified three tightening passes with a specific torques. Additionally, make sure the silicone cures a bit (2...5 mins) prior You land the LIM. But it has to have a "wet" looking yet.
You may reuse the old bolts, that's not an issue.
