Vehicle Jerks when turned on.
Old Nov 5, 2009 | 05:58 PM
DrEaMsTeVe's Avatar
DrEaMsTeVe is on a distinguished road
Question Vehicle Jerks when turned on.
Hi,
This has been going on since I bought the vehicle. When I start the vehicle and it turns over, the entire cabin Jolts. Its right when the vehicle turns on and its intermittant. I wanna say it happens 85 percent of the time and the other 15 percent it starts without a jolt.
What do you guys suppose would cause this? No error codes what so ever and it doesn't seem to be hurting the vehicle though I am curious to the cause.
Regards, and thanks in advance.
Old Nov 6, 2009 | 01:18 AM
blzR's Avatar
blzR is an unknown quantity at this point
I had that very problem consistantly just the same,the problem for me went completely away since i installed a new tranny 3yrs ago.
Old Nov 6, 2009 | 07:01 AM
DrEaMsTeVe's Avatar
Thanks, I wonder if it will make a difference when I install the Transgo kit to fix some idiosyncrasies with my trans in a few weeks....
Trans downshifts like a grandma on WOT sometimes and my 1-2 bump came back. Been an issue for as long as I've had the vehicle.
Old Nov 6, 2009 | 09:00 AM
zedartwo's Avatar
where are you getting your Transgo kit? and how much? its for the 4L60-E right?
thanks!
Old Nov 6, 2009 | 09:30 AM
DrEaMsTeVe's Avatar
Yeah. It's the SK 4L60E kit. Shift Improver. I don't want a performance kit. I have the option of finding it cheap at ebay and doing it myself or going through a transmission buddy of mine for $150 part/labor.
I'm leaning on letting my trans guy do it. The instructions weren't nice to the little bit of understanding that I have regarding the transmission.
Old Nov 8, 2009 | 09:46 PM
zedartwo's Avatar
perfect!, thanks alot!
Old Dec 4, 2009 | 12:44 AM
SWC1969's Avatar
SWC1969 is on a distinguished road
Default Tsb 08-07-30-026
GM TSB on the subject:
INFORMATION Bulletin No.: 08-07-30-026
Date: May 22, 2008
Subject:
Information on Slight Vehicle Movement In Park At Start Up After Cold Soak
Models:
2009 and Prior GM Passenger Cars and Light Duty Trucks (including Saturn)
2009 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X with Automatic Transmission
Some vehicles may rock or move slightly forward or rearward while in park at start up after cold soak. This condition may be accompanied by a clunk noise. This is a slight movement that is more often seen visually, rather than felt, when viewed from the outside and using the auto-start feature, if equipped.
This slight movement is due to the residual transmission fluid in the clutch packs that creates a partial apply on start up. This movement is stopped by the parking pawl and/or transmission fluid exhausting completely from the clutch packs.
This slight movement has no adverse affects on the transmission and no repair should be attempted. This condition is normal. This can be verified by comparing with another identically built vehicle under the same cold conditions.
To prevent this condition from occurring, the parking brake should be utilized as per the Owners Manual recommendations anytime the vehicle is parked.
Old Dec 4, 2009 | 01:51 AM
okvortec's Avatar
^^^^^ That sounds like a good source, what is it?
Old Dec 4, 2009 | 02:51 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Just don't do that in sub-freezing temps. Unless you plan on calling in sick the next morning because you can't move your vehicle.
Old Dec 4, 2009 | 07:03 AM
That is a GM TSB (technical service bulletin). I have posted this in the past as well. It really is not much to worry about.
You could flush the transmission and fill it up with Dexron VI which is a fully synthetic transmission fluid that flows better when cold.
