when turnin steering wheel alot to one side makes a popin noise what is it?
I have a 95 blazer and not always but sometimes when im backin out of a parking spot or turning the wheels alot one way but driving slowly i hear like a pop noise and i took it to the mechanic and he he said he doesnt know what it is. Can anyone tell me what this might be? Thanks in advance.
RE: when turnin steering wheel alot to one side makes a popin noise what is it?
Could it be the strut bearing on top slipping/moving around(worn out)..i had a big issue on my Grand am with the strut bearing turning and popping noises.Worth a check anyhow.
Blazer's don't have struts... So no strut bearing.
If it's when you turn, there are a few possibilities... Broken anti-sway bar end link, but I'd hope your mechanic could pick up on that. Worn tie rod ends, idler arm or a worn pitman arm - if bad enough and left unattended long enough, these may result in wear on your tires. Or worn ball-joints.
To test the steering components, make sure that there isn't any pressure on the steering linkages by parking on a level surface. Grab ahold of each of the components in the steering and check for play.
With the balljoints, I usually lift the front end off the ground and support on jackstands, then I slide a fairly long 2x4 under one of the front tires and lift up. If you hear a pop, then that is mostlikely the lower ball joint. The upper can be checked with the steering all the way to one side so you can see the upper control arm and upper ball joint. Put a pry bar under the upper control arm and lift up. Again, if you hear/feel a pop, then the ball joint is mostlikely worn and needs replacement.
Hope this helps!
Hope this helps!
I had this problem last year with popping noise when backing out of driveway with wheel turned. I did like Kyle explained and found the drivers side lower ball joint was excessively worn and so I changed both lowers....So fire your mechanic - he should have found this problem if you paid him then ask for partial refund....
BlazinHo
05-11-2014 06:09 PM
Irish07
10-31-2012 06:04 PM
upmaine
07-09-2012 12:31 PM
strongboy2005
Headers, Intake, & Exhaust
02-06-2006 08:23 PM
