Where does this small hose go to?
Old Nov 9, 2011 | 09:39 PM
comandoed's Avatar
comandoed is on a distinguished road
Default Where does this small hose go to?
I have 2000 4wd 2dr Blazer. Bought this Blazer 4 months ago and havent
figured out where this hose goes to. Its on the drivers side, upper motor
area. See picture attached.
Old Nov 9, 2011 | 09:54 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
it plugs into the back of the black ball right above it attached to the hood. i think its called an accumulator (cant see it in the pic) right now your 4WD wont work with it unplugged.
Old Nov 9, 2011 | 10:01 PM
comandoed's Avatar
Hmmm. Truck is running. I'll have to go look for black ball. What is accumulator?
Old Nov 9, 2011 | 10:07 PM
Rottidog's Avatar
Pretty sure it's a vacuum hose, look for an open plastic tube/"T" connection that it would plug in to.
To make sure it's a vacuum hose plug it or spray a little brake cleaner in it while the engine is running. If the engine changes how it runs IE smoothes out or revs higher with the brake cleaner, it's a vacuum hose. Your mileage will improve a lot too.
But you have to find out where it's supposed to be, possibly like "97" said, I'm not sure.
Old Nov 9, 2011 | 10:44 PM
chris015's Avatar
There you go....and whoa pic got big...i think it'll be ok.
Old Nov 9, 2011 | 10:55 PM
comandoed's Avatar
Cool lifesize pic Chris. Really appreciate explicit answer. lol I printed pic
and tomorrow I'll hook it up. Might have to get longer hose if current one
has been shortened.
Old Nov 9, 2011 | 11:00 PM
chris015's Avatar
Yea,didnt mean for it to be that big. lol
That hose shouldnt be more then 89 cents a foot. just bring that piece with you.
And that vacuum ball,if its the round toilet ball looking one,its important. it gives you vacuum boost for the heat/air etc too. i had a lumina i wrecked and it crushed the ball.i plugged it. well the air would only blow hard when i was moving. at redlights it would barely blow....to find out it was because of that vacuum ball.
Old Nov 9, 2011 | 11:16 PM
Rottidog's Avatar
From the pics it looks like his is the vaccum hose that goes to the canister in the fender. Ugh, lots on that fender to remove to get in there. Maybe it can be done or reached around to from the fender well?!
Old Nov 10, 2011 | 01:27 AM
Well if that black ball attached to the underside of the hood right above that area doesnt have a hose attached to the back of it then thats your problem. im almost 100% sure thats what it goes to because mine has come off before and it took me forever to figure out where it went, and it was in the same exact location and same exact length of hose as whats in your pic
Edit: unless that round ball im talking about got relocated to inside the fender in later years past '97 then i suppose it could go there. but just pop the hood and you will see.
Old Nov 10, 2011 | 05:02 AM
coolasice's Avatar
coolasice will become famous soon enough
the 2000 has it in the fender, it is a Bitch to get on but can be done without removal of anything. it should be just behind the abs module kinda hidden.
