Won't start after body lift
Old 05-07-2015, 09:48 AM
madmaxxed's Avatar
madmaxxed is on a distinguished road
I don't think it's a passlock issue where i'm not getting the flashing security light when i try and start the engine. I don't think the fuel pump would kick it just like that. The fuel pump relay is okay and all the fuses are good. I'm going to trace all the wiring back from the tank and up. Fingers crossed again.
Old 05-07-2015, 09:56 AM
newguy's Avatar
passlock stop injector poppets from opening. doesnt effect pump
Old 05-07-2015, 10:19 AM
madmaxxed's Avatar
I don't hear the fuel pump kick on but I doubt the fuel pump is shot just like that. I feel it's too coincidental. It ran fine the day I started the BL and now it doesn't.
Old 05-07-2015, 11:27 AM
DesertStorm's Avatar
if you dont hear the fuel pump prime, and all the fuses relays are good. make sure you have power going to the pump. more than likely will need a new pump but could be a loose connection somewhere from when you put the BL lift on.
Old 05-07-2015, 12:05 PM
LeWhite's Avatar
In the fuse block under hood locate the fuel pump relay. Next to the pump relay there are two empty slots. Short those slots with a very small wire and re listen for the pump.
Old 05-07-2015, 12:31 PM
newguy's Avatar
Connect a jumper wire to a positive, like the one on the underhood fuse block. put the other end of the wire in the spot shown. If pump is good you will hear it
Old 05-07-2015, 12:47 PM
madmaxxed's Avatar
Thanks guys. i'll try that when i get home today.
Old 05-08-2015, 01:19 AM
LeWhite's Avatar
If pump fails to run look for broken ground wire possibly to the inside of the cross member.
Old 05-09-2015, 06:27 PM
madmaxxed's Avatar
I dropped the gas tank today and pulled the fuel pump. Ordered a new one with lock ring.
Old 05-09-2015, 10:48 PM
LeWhite's Avatar
As per others before me: OEM delco only!
Quick Reply: Won't start after body lift
