00 computer climate control issue
Old Aug 11, 2008 | 08:35 PM
toaks's Avatar
toaks is an unknown quantity at this point
Default 00 computer climate control issue
Ive got a 2000 Jimmy SLT with computer climate control. I am only getting heat when I have the temp **** on the "red" setting which Im assuming is "max heat". There is no temp change when I toggle through the temperature settings (ie 66, 70, etc). The heat blows steaming hot when it is on the hot setting, and both heater core lines are very hot when I checked them.
Ive read through some old threads on similar problems and tried the re-calibrate procedure of the blend door by removing the RDO fuses and the HVAC fuses, but it doesnt seem to do anything for me. I also pulled the blend door actuator off and verified taht it is moving correctly when i rotate the temp switch and it seems to be.
Any suggestions? could it be the thermocouple for the cabin temperature has gon bad? or could it be the computer climate control module in the dash itself? Also, sometimes there is a strange "humming noise" coming from the dash, sounds like it could be coming from the climate control module, but this noise is only intermittent.
Any help greatly appreciated. Thanks.
Old Aug 11, 2008 | 09:15 PM
Default RE: 00 computer climate control issue
So it always pumps heat out regardless of the temperature setting? Sounds like the control module may be fubar'd
Old Aug 11, 2008 | 09:46 PM
toaks's Avatar
It does not always pump out heat, it only puts out heat when it is on the highest setting. When it is on anything but the highest setting it feels like it is just at ambient temp (when the a/c is off of course).
Old Aug 12, 2008 | 12:52 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
I have a computer climate control thingamabob, from my parted out 98 Jimmy, for sale. Let the bidding begin!
Old Aug 12, 2008 | 07:56 PM
cjpost's Avatar
cjpost is an unknown quantity at this point
I have the same thing going on with a 99 Blazer. Figured that it was the contral panel, since it apparently has the controls and a control board inside. Paid $90 plus $8 shipping for a used one. I WISH that I could say that it fixed the problem, but nope. I've tried the re-calibrate option too many times to count.[:@] It looks like getting inside the dash to look at other items will not be a fun thing to do, but will be attmepting it this weekend.
BTW - forgot to mention. Mine was working great, until I had to replace a dead battery, so you'd have thought that the re-cal procedure would have been all that was required.
rsvensson
14
Feb 9, 2014 06:01 PM
Rafiki
Aug 11, 2012 12:33 AM
lizardking88mph
Jul 22, 2011 10:28 PM
screwd_newfie
Nov 4, 2010 12:37 AM
DaveHearne
Feb 19, 2010 08:32 AM
