01 blazer 4wd not releasing
Old Jan 15, 2013 | 05:16 PM
blazinrick's Avatar
blazinrick is an unknown quantity at this point
Default 01 blazer 4wd not releasing
going from 4 hi to 2hi front axle stays engaged replaced the vacuum solenoid valve but no change
Old Jan 15, 2013 | 05:23 PM
3 or 4 button switch on the dash?
Is it equipped with a 3 port vacuum switch on the transfer case, driver side, inboard and above the encoder motor?
Old Jan 15, 2013 | 05:29 PM
blazinrick's Avatar
4 button
Old Jan 15, 2013 | 05:47 PM
Check post #2 again.
Old Jan 15, 2013 | 06:09 PM
blazinrick's Avatar
no vacuum switch
Old Jan 15, 2013 | 06:31 PM
With the engine at idle, select 2WD: is there manifold vacuum to one of the vacuum lines on the switch that you replaced, (on the firewall)?
Old Jan 15, 2013 | 06:47 PM
blazinrick's Avatar
yes, when i select 4 hi it pulls in the vacuum diaphragm under the batt. box but when i go back to 2hi the diaphragm stays pulled in untill i release the vacuum line that attaches to it
Old Jan 15, 2013 | 06:59 PM
Unplug the 2 vacuum lines from the vacuum switch, engine at idle, select 2WD: One port on the switch should hold vacuum when you suck on it The other port should be vented to atmosphere.
The port that holds vacuum must have the engine vacuum line connected to it. The line that goes to the other port goes to the actuator under the battery tray.
This will tell if the lines got transposed, (switched around).
Old Jan 17, 2013 | 04:57 PM
blazinrick's Avatar
that worked thanks captain !
Old Jan 17, 2013 | 07:11 PM
Good job! Thanks for posting back.
justblazin1
Oct 19, 2014 11:12 AM
cory30189
Jan 31, 2013 07:04 AM
ensembledwar
Mar 7, 2010 12:13 PM
LYK2ROC
Dec 5, 2008 07:08 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
